Originally Posted by mike slater
 these are wild 1 wo515 ...10'' baby apes, no cable changes needed
Originally Posted by Rmohd
Mike how do you like them ?
I have the same Apes on my 05 road glide, they are actually the same stock bars on a Dyna Wide Glide pre 08.
Stick with these bars and you shouldn't have any problems to replace any lines or wiring. you may need to do a little tweaking with the brake line and clutch cable will need to be routed a little differently but its a GO..
These bares are 100X better than the stock bars and it really has nothing to do with the height, it all has to do with the position your wrist twisting outward on the mini apes. I found the stock bars made my wrist twist too much inward causing my shoulders to hurt.
