Originally Posted by RVROD
Not that tough at all worse part is pushing the new hose on to the fittings it is VERY tight
Should I replace the screws with rubber on the access cover to the filter? as long as they dont look damaged.
Is it necessary to replace the hose in the tank while changing the fuel filter?. I thought that all you had to replace was the fuel filter canister and the crimped hose clamp. Any knowledge from experience is greatly appreciated. I have been a auto mechanic for 35 years, but never change the filter on a 07 flht, just wanting to make sure i have all the right parts on hand when i go inside the tank.
