AdvanstarMotorcycleShowsBub EnterprisesLeslie Kay'sPro PadMotorcycle-CommunicationFuel MotoCycleGear.comProCharger.comRRcycles.comBikeBandit
Old 11-01-2009, 07:50 AM   #1 (permalink)
STS04
Click clack rattle
Had a 04 88b with SE pipes from day one. Never noticed any engine noise. New 2010 Ultra is noisy. Stock pipes and under 1000 miles, strange noises from the engine at all speeds. It might ease up a bit after 2000 rpm. Is this just me being picky or normal?
STS04 is offline   Reply With Quote
Old 11-01-2009, 08:39 AM   #2 (permalink)
shrinkman2 is on a distinguished road
You're gonna hear everything from "get louder pipes" to "you shoulda heard my shovel" and such...My opinion is NO it is not normal....However, a bunch of them do it. The other side of the coin is...a bunch of them do not (not talking specifically about the 2010's as I don't know so much about them). However, this topic has been going on for awhile. I've got an 05 and it sounded like the push rods lost contact with the rockers...from day one. Rebuilt the motor and it finally got much quieter..but got two different sets of lifters that at least one was defective. I went with 60 wt oil which seems to help (live in deep south). It seems to me that the tolerances are much too loose when these engines are built from the factory and some are looser than others. Hope this helps
2005 Road King (Carb)
1550 SE 95" Flat Tops
R&R 525 Cams
Hyperformance Heads
Cometic .030 Head gasket
R&R Internal cam plate/oil pump
K&N Air Filter
Fullsac True Dual kit
Vance & Hines slip-ons
SE High Perf clutch spring
MRC Easy Clutch
shrinkman2 is offline   Reply With Quote
Old 11-01-2009, 11:04 AM   #3 (permalink)
20538 will become famous soon enough
are you keeping it under 2000 rpms if so that might be your problem. The HD mechanic told me these motors like to run between 2500-3500 rpms.
20538 is offline   Reply With Quote
Old 11-01-2009, 11:39 AM   #4 (permalink)
TRazzo's Avatar
TRazzo is on a distinguished road
That is what my service writer told me too, don't run them under 2K if you can help it, they like it over 2K much better, and the noises do subside after 2500. Mine is very noisy, my metric was much quieter but it was also OHC.
105th Anniversary FLHX - Sorta........
TRazzo is online now   Reply With Quote
Old 11-01-2009, 12:39 PM   #5 (permalink)
06roadglide is on a distinguished road
Did your 04 have a fairing? If not, then that might be why 2010 seems louder.
06roadglide is offline   Reply With Quote
Old 11-01-2009, 05:09 PM   #6 (permalink)
STS04
No fairing, it was a softail standard. I love the new Ultra, just takes some getting used to I guess. The 88b did not vibrate at all. thats a big getting used to. I will probably get some slip on pipes later, that might take my mind off the noise. Thanks for the replies.
Old 11-01-2009, 05:51 PM   #7 (permalink)
Dumb AND Stoopid
wurk_truk is on a distinguished road
This is SO true!
wurk_truk is offline   Reply With Quote
Old 11-02-2009, 08:40 AM   #8 (permalink)
msocko3's Avatar
msocko3 is on a distinguished road
The fairing and the lowers will have you hearing noise you had but didn't hear on your softail. Before getting slip ons you might want to listen to some other 2010's with the stock head pipe and slip ons. I heard 2 Ultra LTD's, one stock and the other had Rinehart slip ons. The one equipped with the Rinehart slip ons sounded almost like the stock one, it just had a touch deeper note but not louder note. The catalytic converter they put in the head pipe also works like a pretty good muffler.
Blue and Silver Triglide Powered By The Underpowered Hot Running Bike Builders Of Harley Davidson.
msocko3 is offline   Reply With Quote
