Custom DynamicsCycleGear.comSportbikeTrackGear
Pro PadAdvanstarMotorcycleShowsFuel MotoAmerican Side Road CycleJardineProducts.comMotorcycle.com Classifieds!
Old 10-25-2009, 08:03 PM   #1 (permalink)
Serpa is on a distinguished road
Handling question
I notice there is a long list of braces and gadgets at the top of this forum. I assume these are to resolve a handling issue? You'll have to excuse my ignorance, I've been out of the loop on Harleys since about 2002.
Serpa is offline   Reply With Quote
Old 10-26-2009, 12:17 PM   #2 (permalink)
qtrracer is on a distinguished road
It does occur but I would not lose any sleep over it, some guys never experience it , some do. I have and don't run a stabilizer...yet but I am replacing my rear shocks to Ohlins and going to the standard height. If I still need a stabilizing device I will get one then.
08 SG 103" SE MVA Heads SE 10.5 Pistons SE 251 Cams SE 58 mm TB RB Racing 2-1
qtrracer is offline   Reply With Quote
Old 10-26-2009, 02:43 PM   #3 (permalink)
The story of my life!
ceraaa42's Avatar
You don't need it on 09 and new bikes since they changed the frames. At least I have not read anyone complaining about it.
It made a huge difference on mine in the wind and the wind buffet from semi trucks on the hyways.
I wouldn't be without it.
Chris
Candy red sunglow
103"
SE255 cams
SE Air cleaner
Fatcat Quiet baffle
Bagger brace
43 member
Old 10-26-2009, 05:47 PM   #4 (permalink)
pends on how ya ride. takes very little push to need all the stabilisers on a HD. if you ride like grandma, you will be fine.
Old 10-27-2009, 03:13 PM   #5 (permalink)
Ozglide
The link between the swing arm and the frame is kind of weak. Most of these gadgets try to stiffen the link with shackles between the frame and the swing arm. I believe that the cause for the wobbles is due to the shaft and rubber bushings flexing too much. When the bike is out of alignment or the engine mounts are worn it increases the problem. I have seen a couple of products that treat this problem directly instead of the symptoms. One is the Sta-bol poly bushings which I have no experience with, the other is the "Glide-Pro" system which I do have on my bike and highly endorse. It replaces the swing arm shaft with a high-strength steel shaft plus beefs up the rubber bushings with poly inserts. The results have been great for me. I am upgrading and adding the poly motor mount soon, I have the new mount, just haven't had time to install it yet. I have ran the Glide-Pro shaft and poly bushing inserts for two years now and swear by them. If you use this link and watch the home videos this guy has created to show how to install his system it will explain the system better then I can. He also has a video on bike alignment that is awesome. Go to the site and then click on the install link for the videos...
http://www.glide-pro.com/stabilizing-system/
Let Freedom Ring
Ozglide is offline   Reply With Quote
Old 10-27-2009, 09:03 PM   #6 (permalink)
allen sputhe designed the original, theb rest are take offs of his idea. just like most jims and other marketable items, allen drew the original plans.
IMHO, true track with bronze bushings is the ultimate for launching (as we tested with the AMRA bagger) if you want a less harse ride, go with poly bushings. even smoother? go with the rubber .
Old 10-28-2009, 01:00 PM   #7 (permalink)
Ozglide
But if you want to cure the wobbles, you got to firm up the pivot point laterally like glide pro and other products attempt to do. I have not noticed a reduction in "smoothness" in my ride, on the contrary the bike tracks like it should with no noticable firmness increase in shock damping because the shocks dampen inputs along the radius of travel allowed by the piviot point between the frame and the swing arm. The lateral movement due to weak shaft and rubber uninforced bushings causes the bike to wobble some in turns due to inperfections in the road surface and/or wind force inputs. Alignment of the engine, frame, swing arm etc. can contribute along with engine vibration from worn mounts.
I'm not saying that other "cures" don't work as well as the one I chose to use, I'm just saying that it does work and if you watch the guys videos he does a good job of explaining why the stock bikes feel mushy and wobble at times during high speed turns. Anyone who is looking to understand why his pre 2009 touring bike does this would benefit from going to this guys web site. What if anything you choose to try to correct this problem or condition is your business.
Let Freedom Ring
Old 10-28-2009, 01:15 PM   #8 (permalink)
hey ozzie! i was saying the same thing! there have been some to complain of vibration/harshness with the firmer bushings and mount. they are really feeling more road and tire. thats why i put the options in there.
as usual, we are on the same page, you just talk funny. LOL
Old 10-28-2009, 01:23 PM   #9 (permalink)
strokerjlk's Avatar
just like most jims
Dennis
u talking bout me
07 ULTRA
S&S 106 CI
Big Boyz heads
D&D Fatcat
Hillside/Green A/C
SE 204
GARMIN 2610
3 GAL. AUX FUEL CELL
IBA# 31913
BBG
1566 MI 23 HR'S
Thomas Jefferson
strokerjlk is online now   Reply With Quote
