Quick release cam-lock press in bolt part number : V-Twin Forum: Harley Davidson Forums
Old 10-06-2009, 10:27 PM   #1 (permalink)
jeepman222 is on a distinguished road
need to find the pressed in bolt for QR cam my dealer says not available any help on a part number
jeepman222 is offline   Reply With Quote
Old 10-06-2009, 11:24 PM   #2 (permalink)
TBo
TBo's Avatar
TBo
You may try a fastener business and see if they can help you.
TBo is offline   Reply With Quote
Old 10-07-2009, 12:13 AM   #3 (permalink)
Divertim's Avatar
Divertim is on a distinguished road
I tried to find one last year the dealer told me the same thing.
I never did find one.
GMR Performance 98 inch
R&R cast heads 1.940/1.615 R&R 615/585 cams
S&S roller rockers Andrews gear drive
HP Inc. 55mm throttle body D&D Fatcat, w/quiet baffle
Primo Rivera Pro clutch
Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery.---- Winston Churchill
Divertim is offline   Reply With Quote
Old 10-07-2009, 06:32 PM   #4 (permalink)
TRazzo's Avatar
TRazzo is on a distinguished road
I have spent hours on the 'net looking for those for the mounts I am fabricating and have had zero luck. I am sure HD doesn't make their own, but I haven't been able to find out who does. They are pressed in like a PEM fastener so you would need a special press setup to get them in without messing them up.
2008 105th Anniversary FLHX - Traded
2012 Road Glide Ultra Ember Red Sunglo
TRazzo is offline   Reply With Quote
Old 10-07-2009, 09:08 PM   #5 (permalink)
pretty easy to remove and install just piece of wood and hammer used the ones off my QD luggage rack to use on wifes prototype rack thought they would be easy to find. guess will try another approach
Old 10-07-2009, 09:30 PM   #6 (permalink)
think I fond it will check tomorrow 45728-95 going to call see if they can order found it in the instruction shhet part break down for RK solo louggage rack hopefully the are pretty standard will post for those who would like to know
Old 10-08-2009, 06:59 PM   #7 (permalink)
well ran part number by dealer he even called someone to to find out the deal number no good unable to get bolt back to square 1
