wobble on 07 road glide : V-Twin Forum: Harley Davidson Forums
Old 09-30-2009, 05:12 PM   #1 (permalink)
Enjoying a great Ride.
jeffsglide's Avatar
jeffsglide wants to know Dino or Syn?
Most of the times you will here about a road glide wobble at high speeds. I feel it at low speeds making a turn, or pulling out of a gas station coming off a small curb, going into a turn I feel she will start to wobble if I dont hold the bars firmly. On the Highway she steady as she goes beautiful. Im on a skillteam here in miami and when we are doing slow turns and figure eights Ill feel the bars shaking, is there anything I can do to fix that problem. Is anybody experncing the same thing. Thanks alot guys.
jeffsglide is offline   Reply With Quote Quick reply to this message
Old 09-30-2009, 10:27 PM   #2 (permalink)
jeffsglide's Avatar
theres 32,000 miles on the bike, I do a lot of riding. True track I'm going to ck that out thanks.
Old 09-30-2009, 10:37 PM   #3 (permalink)
jeffsglide's Avatar
I just checked out the true- track on the website it says for dressers the kit is for 1994 to 03, Im going to call him tomorrow.
Old 09-30-2009, 11:25 PM   #4 (permalink)
shoveler wants to know Dino or Syn?
Have you taken a CLOSE look at the front tire? Try over inflating it by 10 pounds and see if there is change.
One far less likely might be the neck bearings. If you have a bike lift, have someone raise the bike while watching the triple tree and frame joint.
shoveler is offline   Reply With Quote Quick reply to this message
Old 10-01-2009, 01:54 PM   #5 (permalink)
Barney Biker wants to know Dino or Syn?
Sounds like it may be the tire or wheel.
Barney Biker
07 EG
Barney Biker is offline   Reply With Quote Quick reply to this message
Old 10-01-2009, 03:03 PM   #6 (permalink)
chriscalabro's Avatar
chriscalabro wants to know Dino or Syn?
I have found that the FLTR is very prone to the wiggles when improperly loaded (bags) but this is only at 75+ ,mph speeds. I would suspect that it may be time for motor mounts and check the front tire and wheel assembly. All are garage repairs and cheap.
2007 HD FLTR (Road Glide)
R&R 131 Build
R&R Stage V billett Heads
S&S 640 Cams
R&R Billet 131 Jugs
Bassani Road Rage
HPI TB 62 MM
Baker DD7
Baker +1
SE Performance Comp
(1) Jagg Oil coolers
Michelin E3 Rubber
Rivera Pro Clutch Hydraulic
chriscalabro is offline   Reply With Quote Quick reply to this message
