09-15-2009, 03:45 PM
2009 Ultra, oil in air filter
A few posts back I had mentioned that the dealer over-serviced the engine oil by about 3/4 of a quart during the break-in maintenance and I realized it when I checked the bike over after the ride home. The air filter was brown around the bottom and there was oil by the throttle valve and around the vent tubes, not to mention oil all the way up the dipstick.
Now that it's got 2,400 miles on it, the new filter they gave me (when I raised holy hell) is also soaked around the bottom. There are no quantity issues, as it's just a small amount of oil going past the rings and into the intake (or so it seems).
Should I worry or will this stop as the bike breaks in? Dealer said he "has never seen damage caused by over-servicing," and was very apologetic.
School me, hog riders, it's much appreciated.
09-15-2009, 04:28 PM
My dipstick sez, "Caution, Do Not Overfill". I always run mine 1/2 quart low to avoid blow-back. I'd be apologetic, too. He probably forgot to tell you that he'd thrown in a free quart of oil.
09-15-2009, 05:56 PM
Ironbutt
Blow-back - oil leaking from your air filter is a common problem with Harleys. Some do it worse than others and usually becomes more of a problem with stage one and other mods. Running your oil half-way between add and full will help prevent this problem but is not a cure-all. Do yourself a favor and change the oil/filter yourself.
Current bikes in the stable:
2009 Street Glide
2003 Heritage Softail Classic
09-15-2009, 08:34 PM
mooooving out!
Most HD v-twins do this at one rpm or another. run it 1/2 quart low and find the rpm that is the problem and don't cruise there
43%er
Bi-polar and loving it!!
Bi-polar and hating it!!
95" w/ KB pistons (flattops)
HQ575 cams
Atwood's Road Warrior Heads
HPI bored throttle body
.030 head gasket
SuperTrapp Supermeg 2in1
"43" points cover
TRW rear mount
obligatory Baisley Spring
Just sayin..........
09-15-2009, 09:27 PM
FYI
That is not oil going past the rings and into the intake. The top end of the motor is also supplied with oil for cooling and lube. This is where the oil mist comes from that ends up in the air cleaner.
06 Ultra
06 Deluxe
08 Nightster (Salt Racer)
09-16-2009, 10:56 AM
Your bike sounds like it is working as desinged. The breather tubes vent air pressure created by the pistons moving up and down. A by-product of this is a small amount of oil vaper comes out also. The EPA won't let the manufatures vent that oil onto the ground, so they vent it into the intake so that it gets burned (in theory). You end up with a small amount of oil residue being left on the filter backing plate that drips down and gets absorbed by the filter when the bike is not running.
I have had 3 differant air filter systems on my bike and they all suffer from this. My solution is to wash the filter every 2500 miles instead of at the 5000 mile interval suggested in the service manual.
Elmo
2007 FLHR
Heavy Breather
Sampson Dark Duals
09-16-2009, 11:08 AM
Ironbutt
Wish it was that easy. My SE cleaner, with K&N filter, started driping after around 500 miles. Another thing you can do is push a small sponge or sanitary napkin between the filter and the cover - at the bottom. Don't tell anyone your bike is on the rag though.
2009 Street Glide
09-16-2009, 12:27 PM
I'm running a heavy breather now and the oil pools in a chamber that has chrome plugs with an O-Ring that holds them on. When this chamber starts to fill up it starts to leak out and splatter on the front of the saddlebag. The good thing is that the caps pull off fairly easily and a paper towle cleans up the oil. Something that can be one at the gas pump.
Elmo
2007 FLHR
Heavy Breather
Sampson Dark Duals
09-16-2009, 02:05 PM
I have a spike air filter on my bike (similar to the SE heavy breather) and all I did was take the breathers that came with my filter, ran them into a "t", then ran that line all the way to the back of my bike....now there is no more oil in my intake AND no more oil down the side of my bike after a couple of hard runs!!!
2008 HARLEY ROCKER C
-HIGH FLOW CHROME SPIKE AIR CLEANER
-V & H BIG RADIUS PIPES (BLACK W/O BAFFLES)
-V & H FUEL PAK(SIMPLE AND HIGHLY RECOMMENDED)
-SOME OTHER COSMETIC STUFF
-SPEAKERS FROM CYCLESOUNDS (THEY SOUND REDICULOUSLY GOOD!)
-PROCHARGED!
09-16-2009, 05:13 PM
I just read in the owner's manual, these filters get cleaned, not replaced at normal intervals. How much is one of these and how long to they typically last before needing replacement?
09-17-2009, 08:47 AM
Harley stock filters usually last about 10K miles but I prefer the K&N a better quality and is guaratneed for the life of the bike.
09-17-2009, 09:58 AM
moose is loose
yup.. if you had oil going past the rings you would be burning it not goint into the intake.. although the design of the breather is that it is thrown into the air intake to be burnt.
99 flhtc 95"
p&p heads
screaming eagle pistons 10-1
sc cams "mild" soon to be 260's
sc igniton and coil and wires
44mm sc carb kit
fulsac true duals
samson rolled thunder slip-ons.
sc intake kit
coming soon
adj push rods
sc 260 cams
manual compression releases
accel wires
sc clutch kit
sc htcc heads or nrhs ported heads possibly dimond cut everything
09-17-2009, 02:08 PM
My 110" with Stage I does the same thing since new (now with 20K on the clock). It's just oil carryover from the crankcase caused by the pistons coming down on their stroke and ejecting air from the crankcase with some oil mist.
I just remove the filter every 500 miles and wipe out the excess before it gets a chance to wet down the paper element. Then at 1000 mile intervals I wash it in hot, soapy water and let dry. I have a spare filter I rotate out so there's no bike downtime. On long trips I just wipe it out to avoid having it drip on the motor or blow back on the bags or the missus. Works fine.
T-man
12-27-2009, 11:48 AM
Just took my 09 Classic out for a brisk but nice ride. All ran great. However I have a stage one and SE air filter and when I returned I notice a couple drops of oil on the front of my right bag. Then noticed it was coming from my SE air intake and the bottom of the filter was wet with oil. Any worries? Is this because I have not run it in a month or is it something I should worry about? Thanks
12-27-2009, 08:07 PM
Why cant you just run the crankcase breather line to a small breather filter mounted somewhere on the frame instead? You can mount them virtually anywhere and they come in chrome too.
