Road King Classic Kickstand ? : V-Twin Forum: Harley Davidson Forums
Old 05-03-2003, 09:57 PM   #1 (permalink)
perazzishotgun wants to know Dino or Syn?
It seems that my FLHRCI kickstand allows the bike to lay over too far--almost scares me. My Sporty stands up much straighter. I try to compare to other bikes, but it sure seems to be laying it too far over compared to others. If this something that is adjustable? My service manual doesn't say anything about an adjustment--just how to remove and reinstall. Thanks
Ride what you want...but ride!
perazzishotgun is offline   Reply With Quote Quick reply to this message
Old 05-03-2003, 10:07 PM   #2 (permalink)
elPrez's Avatar
elPrez wants to know Dino or Syn?
I feel the same way with my 98 RKC. Sometimes I look at it and I could swear its creeping forward, ready to fold up and fall. I've had two friends (who own bikes) sit on it and when they put the stand down and get up I almost lunge forward thinking it's gonna fall over. I guess it will take a while to get used to it.
elPrez is offline   Reply With Quote Quick reply to this message
Old 05-03-2003, 10:19 PM   #3 (permalink)
Ed Y's Avatar
There is nothing adjustable on it. You might take a look and make sure the bolts (4) that hold the plate to the frame are all tight. If you look close at the tab on top of the kickstand and see where it is placed when weight is put on the kickstand, you'll see why there is some movement involved. As long as the tab is inserted in the middle of the two upright pieces, the bike might move slightly but will go nowhere.
Ed Y
Retired Navy, MCPO
Old 05-03-2003, 11:32 PM   #4 (permalink)
HDSmurph wants to know Dino or Syn?
Same as Ed Y. Yes its scary, yes it takes time to get use to. Just make sure you put it all the way before sitting the bike on it.
All work and no play is missing the point.
HDSmurph is offline   Reply With Quote Quick reply to this message
Old 05-04-2003, 01:00 PM   #5 (permalink)
I get the same scare--it wants to move forward even on level ground. At my age, I find it even difficult to pull the bike up straight, particularly when I park on less than level ground. Yes the bolts are all tight. I park it in the garage with the stand on a 2" x 6" board, and it seems like about the right angle. I don't carry a board with me though!!
I have thought about permanently adding about an inch of steel to the bottom of the jiffy stand. Any thoughts?
Old 05-04-2003, 01:14 PM   #6 (permalink)
Pestilence
PeterV wants to know Dino or Syn?
Don't do it..........will void warranty on inner primary transmission jackshaft output tracking sensor gear bypass valve.
Honestly..you don't have to do anything. The stand works, live with it.
You can always buy the fancy aftermarket ones
Check this one out
PeterV is offline   Reply With Quote Quick reply to this message
Old 05-04-2003, 02:27 PM   #7 (permalink)
I assume your are kidding about "Don't do it..........will void warranty on inner primary transmission jackshaft output tracking sensor gear bypass valve."??!!!!!!!!
Old 05-04-2003, 02:43 PM   #8 (permalink)
Pestilence
.....umm.......you are correct
Old 05-04-2003, 03:19 PM   #9 (permalink)
harleyhog wants to know Dino or Syn?
Animations powered by elsewhere...
Click da Hog...Go on, ya know ya wanna.
harleyhog is offline   Reply With Quote Quick reply to this message
Old 05-04-2003, 04:09 PM   #10 (permalink)
Close examination on the mechanics of the jiffy stand seem to indicate that how far it lays down (or the stand comes up) is a block of solid steel approximately 1/2" thick that runs down the length of the leg of the stand which is enclosed in the bracket. Cannot tell how it is wedged into the stand frame. It does not appear welded in place. If this block was either thicker or positioned more outboard, it would not allow the stand to pull up quite as much. Make any sense?? I just returned from an independent shop and compared to quite a few bikes. Mine still lays over far more than the others, but there was only one touring bike, an Ultra, to compare to. It stood up straighter, but was an older bike. The indy thinks mine lays down too much, but agreed that he does not know how to adjust. Could it have been improperly manufactured?
Old 05-04-2003, 06:21 PM   #11 (permalink)
rfdjr58 wants to know Dino or Syn?
Probably just common sense, but I usually "take the slack" out of the transmission after turning off the motorcycle -- let it roll a little until the the gear catches. This way it doesn't move after putting the side stand down. It is scary when you see that stand starting to move, even if it will eventually catch.
"I plan to live forever -- so far, so good!"
(Steven Wright)
rfdjr58 is offline   Reply With Quote Quick reply to this message
Old 05-05-2003, 12:37 PM   #12 (permalink)
stonesrock wants to know Dino or Syn?
I thought I was having the opposite problem, the stand wasn't letting the bike lean over enough. If parked on a slight incline, I thought the bike would move forward (kind of like the jiffy stand pushes itself up). Looked at other dresser's at the dealer and found mine was in line with other bikes. All bolts tight, so just the way I parked it on this slight incline where I first got paranoid about the bike tipping over while parked.
Well when you're sitting there in your silk upholstered chair
Talking to some rich folk that you know
Well I hope you won't see me in my ragged company
Cause you know I could never be alone
"Dead Flowers" (1971) -Sticky Fingers-
stonesrock is offline   Reply With Quote Quick reply to this message
Old 05-08-2003, 12:09 AM   #13 (permalink)
I went and measured a few touring bikes at the dealer. Mine lays over the same as all the others. Oh well! I did take a stub of stainless steel rifle barrel and cut it on the lathe .200 thick and .700 round. Dropped it into the kickstand channel. Bike now stands up much better, but I assume I will lose it the first time I ride.
Old 05-08-2003, 01:05 AM   #14 (permalink)
Probably fall over the 'other' way when ya park it!...
