07-03-2009, 12:53 AM
Silver Face Gauges
Anybody make an adapter plug to use newer silver face gauges(06-09)(Street Glide) on an 01 FLHTC-I ? The speedo and tach have different plugs. The air, oil fuel,and volt plugs in the same.
07-03-2009, 07:47 AM
I gotta be honest, the silver-faced gauges suck. When the sun is shining, you can't see the numbers. I'm changing my 2009 Bob's over to black via the speedo/tach combo gauge soon.
Nick
2009 FXDB Street Bob (a.k.a. "Zeta")
- BUB Jug Huggers (05-1375CG) powder coated flat black
- Arlen Ness Big Sucker (1010-0179)
- H-D Screamin' Eagle Race Tuner
07-03-2009, 10:55 AM
Doof Toll Pimp
You wont be able to convert the speedo over as it uses completely different electronics.. the other gauges should not be an issue..
I cannot say about the tach ... it should use the same basic wiring and a different plug but then I am not sure ..
To be old and wise,
Here's to old and stupid....
Orthopedic Motto
DC.....
04 FLTRI
SE Welded/Balanced Flywheel
103 Cubes
CP Hi-Comp Pistons
Andrews 54G Gear Drive Cams
S&S Hi-Lift Valve Springs
Timken Conversion
Baisley SuperSTock Heads
V&H True Dual Headers
Bassani Slip-on Mufflers
Thunder Max Ignition System
Feuling Oil Pump
Custom Feuling Cam Plate
07-03-2009, 12:15 PM
Agreed... it's not just a "plug" issue, but one of system compatibility.
The tach probably won't work either... it's like the speedo now in that it has a computer inside it and wants to "talk" to the other computers on the bike (ecm, speedo, etc.).
ChopperDude
07-04-2009, 01:21 PM
Silver Face Gauges
Will the 4 small gauger be the same?
Thanks,
Les
07-04-2009, 01:22 PM
Silver Face Gauges
Will the 4 small gauges be the same?
Thanks,
Les
07-04-2009, 04:21 PM
Doof Toll Pimp
the in dash (fairing)gauges should be the same even if in different places in the dash...
just look at a schematic drawing to make sure of the wiring....
To be old and wise,
Orthopedic Motto
DC.....
04 FLTRI
103 Cubes
CP Hi-Comp Pistons
Timken Conversion
Feuling Oil Pump
07-04-2009, 08:49 PM
Are you really set on silver?
I cant see the needles or numbers when the sun is over my shoulder shinning on them. 09 RG.
