06-14-2009, 12:43 AM
Road Glide Headlights
Just got in from an evening ride with a couple that got a beautiful used 08 Road Glide - they traded in an 01 SERG. He said the headlights sucked on the 01 - he tried several different bulbs and readjusting the headlights to no avail. He was hoping the new bike would be better, but the lights still didn't cover the road as well as my Street Glide (although I did notice that his were aimed awefully high..) What have you guys done to improve the headlights on your Road Glides or do you find them to be satisfactory? Mine do pretty well, but I want to put in the Sylvania Silver Star anyway. I was wondering what 2 Silver Stars would do in the RG?
105th Anniversary FLHX - Sorta........
06-14-2009, 05:44 AM
EvilMonger
Never been thrilled with my road glide headlights. I would love to do HID if I could find one guaranteed to work with my housing!
06-14-2009, 07:01 AM
Mine seem OK, I can see good and when on HI, the road and ditches are lit up pretty well. A friend has the SG and when he is behind at night, its like his hi-beam is on in the mirror, makes it tough to see unless he falls way back.
Frydaddy
96 Heritage Classic
08 RG Ann.
Navy FE
"There's no present. There's only the immediate future and the recent past." - George Carlin
06-14-2009, 08:35 AM
I traded my 06 Road Glide for an Ultra and my headlight problems were solved. I had installed moto lights on the front forks which helped greatly, but you can forget trying to make the "stock" headlight system on the Road Glide any better because they suck.
Leon
06-14-2009, 04:14 PM
I have an 05 and have no issus like these with my lights.
I removed the ugly cover and installed the housing that comes on a screaming eagle roadglide. and didnt notice any differance.. and again I have no isses road is lit up fine.
06-14-2009, 05:44 PM
Finally
HD fog lights on the engine guard. Problem was solved for me...
"It's The Mirrors"
06-14-2009, 08:41 PM
Gone Postal
Great Lights Here
Road Glides have great headlights when adjusted properly.Mine were set much too high from the factory.Adjusted on them twice,now they perform just great for my 21 mile commute at 4 a.m. Gotta keep the bugs off the cover too.
'06 Road Glide
Fire Red Pearl
Stage 1
K&N air filter
V&H true dual
Monster Ovals
Klockwerks 12" flare w/s
TWR stabilizer
06-15-2009, 09:44 AM
You guys obviously have never ridden a cross bones springer with that little lantern bobbing in the front!  Seriously, I haven't noticed any lighting issues on my road glide but maybe they are adjusted properly.
My last ride was your mom
06-15-2009, 11:23 AM
I have HIDs and Kuryakyn driving lights(which I never need).
here is the HID I used:
http://www.xenonlink.com/H4+Bi-Xenon...e+HID+Kit.html
I learned about this kit on the other forum. I have had it in my bike since Dec 08 and done about 5000 miles and have had no issues. HIDs make a big difference.
2006 Road Glide 95"
HD Stage II Big Bore
SE 203 cam
SE air kit w/K&N
V&H true dual headers
V&H Monster Ovals exhaust
PCIII USB w/custom map
SE 6 speed
HD premium oil cooler
Chopped tour-pak
Ultra style lowers
Clearview windsheild
Chubby pullback bars internally wired
Braided lines
82.49hp
91.29ft-lbs
Bi-Xenon HID lights
Hogtunes upgrade
06-15-2009, 11:38 AM
How much of a difference did the HID kit make? does the stock plastic housing hold up good to this?
Curious because my 06 RG has the silverstars and it is getting the housing hot around the edges and melting. But I do run the high beams in the daytime also.
06-15-2009, 11:52 AM
The best upgrade for RG headlights is the Euro headlight housing.
06-15-2009, 12:11 PM
EvilMonger
Did you do the install?
How much room was behind the bulb/socket? (the stock socket rubs )
Any install pictures?
Want to take some?
Thanks, I am very interested.
06-15-2009, 12:52 PM
Mattman
Sounds like the ticket, what did it end up in$$.
"Old EL Paso" 2006 FLTRI, 95"
Andrews tw37g & SS gear, Torringtons,
SE Premium rods, SS lifters, Cometic .030
SE Wires, SE 25* inj., Stock heads, SE 95" cast FT,
Rebored cylinders, SERT, SE Heavy Breather KN ,
SE clutch spring, Aims VP83S, Synthetics 5 holes,
Bassani Road Rage, Progressive Stabalizer,
Windvest 14", Corbin C. Solo, 880 Metzzlers,
Barrnet cables, WO517's, Sony GT630u & Hog Tunes.
06-15-2009, 04:31 PM
06Roadglide....it made things a lot clearer at night. I have not noticed it melting the housing at all.
Thealien...I did not do the install and fairing was removed a time or 2 after the install to adjust my Hogtunes set up. My indy did not notice any issues.
2006 Road Glide 95"
SE 203 cam
SE air kit w/K&N
SE 6 speed
Chopped tour-pak
Ultra style lowers
Braided lines
82.49hp
91.29ft-lbs
Bi-Xenon HID lights
Hogtunes upgrade
06-15-2009, 04:36 PM
I have seen this mentioned in other posts (forums?); it sends the existing light out in a different pattern and all who had installed it seemed pleased.
Certified Geezer: 05 Road Glide
DoD #0472
DoD credo: "Live to Flame; Flame to Live"
