Counter Balanced Engine : V-Twin Forum: Harley Davidson Forums
Old 05-27-2009, 07:37 AM   #1 (permalink)
wjsmithjr is on a distinguished road
Anybody ever wonder why Harley doesn't put the counter balanced engine in the touring models. I like my Heritage at a redlight much better than my new bagger.
wjsmithjr is offline   Reply With Quote
Old 05-27-2009, 07:56 AM   #2 (permalink)
djmiller is on a distinguished road
My friends ask me the same question. I had a 06 Heritage & traded it for the 09 Ultra Classic. I don't mind the shaking at a stop but I love the smooth ride at highway speed.
djmiller is offline   Reply With Quote
Old 05-27-2009, 08:34 AM   #3 (permalink)
Chart is on a distinguished road
05 Heritage traded for an 07 Road King. Loved everything about the Heritage, everything, except the high frequency vibration that you finally notice about 3 hours into a tour. That became very tiring on long trips. Well, that and the 5 speed transmission. Both of these were problems mostly only on the interstates.
Chart is offline   Reply With Quote
Old 05-27-2009, 08:36 AM   #4 (permalink)
route66paul's Avatar
The reason for the counter balancing is because they are hard mounted. The other models have rubber mounts, and the engine smoothes out with some RPM.
43%er
Bi-polar and loving it!!
Bi-polar and hating it!!
95" w/ KB pistons (flattops)
HQ575 cams
Atwood's Road Warrior Heads
HPI bored throttle body
.030 head gasket
SuperTrapp Supermeg 2in1
"43" points cover
TRW rear mount
obligatory Baisley Spring
Just sayin..........
Old 05-27-2009, 09:27 AM   #5 (permalink)
Premium octane member
TXCHOP's Avatar
I dont know why, but i am sure glad that they didnt!
117ci.
Old 05-27-2009, 02:38 PM   #6 (permalink)
To get a v-twin to run smooth, you have to balance the crank so that it will run smooth at a certain RPM range. Hard mounted motors are smooth at idle and not really smooth at cruising. When the motor gets rubber mounted, you can set it to be smooth at cruise, but it jumps around at idle.
43%er
HQ575 cams
.030 head gasket
"43" points cover
TRW rear mount
Old 05-27-2009, 09:09 PM   #7 (permalink)
Eleft36's Avatar
Eleft36 is on a distinguished road
Allow me to quibble, mine is vibration-less.
Al
Stock 110" mufflers Stock Heads Andrews 26 Cams SE103" BB Kit Zippers Cam Chain Tensioners SE Compensator Mustang Wide Touring Seat Stock Bars H.D. Oil Cooler 1990's LeatherWorks inc Saddle Bags with HD Deluxe modified guards H-D Windshield Thunder Max A/T 2005 S E Tour Pack
Eleft36 is offline   Reply With Quote
Old 05-27-2009, 09:55 PM   #8 (permalink)
springer 03's Avatar
springer 03 is on a distinguished road
Why not rubber mount a counter balanced motor and have the best of both? My softail idles and rides without vibration until 75 or 80. My street glide smooths out after getting moving and is nice and steady until decel and idle.
springer 03 is offline   Reply With Quote
Old 05-28-2009, 05:33 AM   #9 (permalink)
01fxdx's Avatar
01fxdx is on a distinguished road
rolling thunder chassis makes a bagger frame designed fo the b motor for those of you ready to really get custom!!
107" axtel terrorist
thundertek cylinder heads
cams= not woods....
super "D"
loud d&d
2006 fltr
95" all secondhand parts
2009 1125cr. rolling grins.
01fxdx is offline   Reply With Quote
Old 05-28-2009, 04:18 PM   #10 (permalink)
05ChromeUltra is on a distinguished road
I road Gold Wings for years...that's smooth. My '05 Ultra shakes and snorts when at a light, and I Love It..!!! Scares the "Boogie Man" away...!!!
05ChromeUltra is offline   Reply With Quote
Old 05-29-2009, 01:54 PM   #11 (permalink)
screaminrdking is on a distinguished road
My Screamin Eagle Road King was ideling at a friends shop the other day.
A guy and his younger son came in to fill a tire with air, when the son says to me why does your bike vibrate so much. Before I could reply the father said boy thats not vibrating, it's breathing. Couldnt have explained it better
screaminrdking is offline   Reply With Quote
Old 05-29-2009, 02:26 PM   #12 (permalink)
Damn Straight..!!!
Old 05-29-2009, 02:51 PM   #13 (permalink)
facn8me's Avatar
facn8me is on a distinguished road
My 96b with 6 speed is smooth as glass from idle to 85 ish. Never been faster on it as I see no reason. 7700 miles total and 850 miles last weekend and have never noticed any vibration at any speed for any reason. Some like shakers and some don't. That's why we are given choices. One good thing about the rubber mounted engines is ya get to check every bolt on the bike more often as it slips my mind most times cause everything isn't shakin all the time.
2007 Electra Glide
facn8me is offline   Reply With Quote
Old 05-29-2009, 03:02 PM   #14 (permalink)
SFTL-1's Avatar
SFTL-1 is on a distinguished road
I can only guess that they don't use the "B" motor across all lines (except v-rod) because of the traditionalists wanting the Harley vibration. If they were to use the "B" motor on the touring bikes they could solid mount the motor, use it as a structural part of the frame which would allow them the lighten up the very heavy frame they currently use. The touring models also offer better stopping power due to their dual rotor front brake setup and this could cause havoc with the counter balance system if the rear wheel is locked up without the clutch engaged, but this is all just speculation on my part
SFTL-1
04' Deuce
95" w/HTCC 10.5:1
SE 257, HTCC Heads & Intake
Hooker Troublemaker Pipes
SFTL-1 is offline   Reply With Quote
Old 05-29-2009, 09:03 PM   #15 (permalink)
dickey's Avatar
dickey is on a distinguished road
The reason The Moco didn't rubber mount the B motor in the Softail was because they couldn't keep "the look" with the rubber mount system, because you need extra clearance between the motor & the frame to allow for movement. They wanted the motor to be "tight" looking within the frame, without too much clearance. Makes for a better "chopper" look.
dickey is offline   Reply With Quote
