Don't know about the swap fitment, but the only difference between ABS and non-ABS wheels is in the bearings. The ABS bikes have an encoder inside the sealed bearing on one side. If you use non-ABS bearings on an ABS bike, your ABS won't work (obviously). If you don't have ABS, you can use either type bearing.
dog is my co-pilot
2008 Ultra Classic 105th Anniversary Edition
Stage 1 w/V&H Dresser Duals and Classic Turn-downs, Fuelpak and S/E air cleaner
TWR Stabilizer • Wheeldock EZ-Up Center Stand • Savior 250 onboard air compressor • RideTime LED Tourpak & Fender Tip lights • HyperLites 3-ways • 6.5" Polk MM-651 front speakers
