Stainless Ride Specialty AccessoriesFuel MotoSportbikeTrackGear
CycleGear.comBikeBanditDan Vance RacingProCharger.comMotorcycle.com Classifieds!
Cycle Gear
Old 10-03-2008, 06:09 AM   #1 (permalink)
RKJohn's Avatar
RKJohn is on a distinguished road
What is the sensor on rear of Air Cleaner box
I recently changed the air cleaner on my 1998 Roadking Police model for a SE unit replacing the black plastic box. There is a sensor mounted on the back of the plastic box held by 2 phillip head screws and nuts that i didnt mount back to the new style air cleaner. What is this sensor for?(i slip tied it to the wiring harness)
Air intake temp? Where should i mount it?
Also, I am experiencing high idle speeds when hot. Any advice would be appreciated.
RKJohn
RKJohn is offline   Reply With Quote
Old 10-03-2008, 07:24 AM   #2 (permalink)
hardy is on a distinguished road
I assume you have an EFI.
If so there are a couple sensors. a pic would help as I dont have my parts book with me.
- John
hardy is offline   Reply With Quote
Old 10-03-2008, 08:36 AM   #3 (permalink)
Thread Ender
Pikeslayer's Avatar
Yes, it is the air intake temp. sensor. Mount it in the intake air stream if possible.
2007 Street Glide
Obama - raised taxes and likes providing terrorists with lawyers -
Old 10-03-2008, 03:06 PM   #4 (permalink)
elmosac is on a distinguished road
I put on a Big Sucker and there was a spot on the back for the sensor. I put it on and don't have any issues.
Your high idle when the motor is hot would be caused by the false indication the sensor is getting from not being mounted in the correct possition.
Put it back were it belongs and things should return to normal.
Elmo
2007 FLHR
Heavy Breather
Sampson Dark Duals
elmosac is offline   Reply With Quote
Old 10-03-2008, 05:01 PM   #5 (permalink)
RKJohn's Avatar
Yes, it is EFI Evo Thanks for the input, however, the wire is not long enough for me to mount it behind the air cleaner, in a simuler area, does it need to touch the air cleaner backing plate? If so, i will make it happen.
Ride safe
John
