08 RK Classic throwin codes!!! : V-Twin Forum: Harley Davidson Forums
Old 06-10-2008, 11:04 AM   #1 (permalink)
flea402 wants to know Dino or Syn?
I recently installed a set of chubby 518s on my RK Classic. \\; Install went well and everything was fine until the damn chk engine light came on. \\; Cruise was disabled but after shutting down and re-starting it came back online. \\; Check engine light has since turned off but the diagnostics are showing codes P1510 - EFI Limited Performance Mode and P2138 - TGS Correlation Error (Twist grip sensor). \\;Just put 80 miles on it today and she seems to be running strong but i cant clear these codes? \\; Anybody have any ideas as to what the problem might be?
Your input is greatly appreciated
flea402 is offline   Reply With Quote Quick reply to this message
Old 06-10-2008, 11:08 AM   #2 (permalink)
HATER OF THE GRAVEL!!!!!!
Jeffytune's Avatar
Jeffytune is reading this now saying WTF is this?
You need to pick up the Electrical repair manual to diagnose it correctly.
I'm Just Sayin'...
2010 FLHTCUI
96 CID w/ the quiet 6 speed
K&N RK-3930 air filter
Harley quiet high flow 110 mufflers
Vance and Hines Fuelpak
Professional Rockat Surgen
Disclaimer.
Jeffytune is offline   Reply With Quote Quick reply to this message
Old 06-10-2008, 11:32 AM   #3 (permalink)
2005 Road King Classic
wkohn wants to know Dino or Syn?
Try pushing the plugs into the sensor again. Sometimes they seem like they seat but don't. You might have to even push on the wire with a pliers to get them to seat.
wkohn is offline   Reply With Quote Quick reply to this message
Old 06-10-2008, 07:27 PM   #4 (permalink)
Hobe wants to know Dino or Syn?
You are getting the errors as a result of the drive by wire throttle, you will get these 2 codes when it is out of calibration. I just went through the same thing, after I reset the throttle calibration and cleared the codes the problem was solved.
This appears to be a common problem with the new electronic throttle setup.
Brotherhood of Warriors VMC
WFFW
Hobe is offline   Reply With Quote Quick reply to this message
Old 06-11-2008, 12:26 PM   #5 (permalink)
how do u reset the calibration for the drive by wire throttle?
Old 06-11-2008, 05:42 PM   #6 (permalink)
This is a repost of the data from the Doof site
Here is the process for checking codes and resetting codes. It is followed by the recalibration procedure that is not posted verbatum, it is just from my experience resetting my throttle.
The codes that I had on my E Glide were 1510 limited perf mode and 2138 TGS Correlation Error (Twist grip sensor)
The IM (instrument module) is capable of displaying DTC's (diagnostic trouble codes).
Speedometer Self Diagnostics: The speedometer is capable of displaying and clearing speedometer, tachometer, TSM/TSSM and ICM/ECM Diagnostic Trouble Codes (DTC).
1- Turn Ignition switch to OFF & Run/Stop switch is to Run.
2- Push odometer reset button in & hold.
3- Turn ignition switch to Ignition and release odometer reset button. Background lighting sould illuminate, speedometer needle should sweep its full range and indicator lamps (battery, security, low fuel, check engine and cruise) should illuminate. The word “diag” should then appear.
4 - Push the odometer reset button once and you will see the selection menu "PSSPt" with the first P flashing.
5 - Each letter represents an area of the diagnostics module. The module that is flashing is the one you are going to check. To move from one letter (module) to the next, you push the odometer reset button one time. (from P to S to SP to t and back to P, etc.)
P = ECM/ICM (Electronic Control Module [EFI] / Ignition Control Module [Carbureted])
S = TSM/TSSM (Turn Signal/ Turn Signal Security Module)
SP = speedometer
T = tachometer
6 - To get the DTC within an area of diagnostics, push and hold the odometer reset button in for 5 seconds and release. If there are any DTC’s the code will be displayed or the word “none” will appear if there are no DTC’s. Push the odometer reset button again to view additional codes if they exist.
7 - Record the codes.
8 - If DTC’s are not to be cleared, Press and release the odometer reset button. Part number of module will be displayed.
NOTE: To determine if a code is current or historic, clear the displayed code by pushing in and holding the odometer reset button ( longer than 5 seconds) until 'clear' comes up. Release the odometer reset button. Turn OFF the ignition switch. Run your bike and shut it down then recheck the DTC’s again by repeating steps 1 to 9. If the code is current it will reappear.
9 – Press and release the odometer reset button to continue to the next module.
10 – Turn Ignition switch to OFF.
On models not equipped with a tachometer "No Rsp" will appear when the tachometer identifier is selected.
"No Rsp" will also appear if the run/off switch is in the off position when doing this procedure.
HFSM = Hands Free Security Module
TSM = Turn signal module
Priority/DTC/Fault condition
1. P0605 ECM FLASH Memory Error
2. P0603 ECM EEPROM Memory Error
3. U1300 ECM Serial Data Low
4. U1301 ECM Serial Data High
5. U1097 Loss of Speedometer Serial Data to ECM
6. U1064 Loss of TSM/FSFM Serial Data to ECM
7. P1003 System relay contacts open
8. P1002 System Relay Coil High/Shorted
9. P1001 System Relay Coil Open/Low
10. P1004 System Relay Contacts Closed
11. P1009 Incorrect Password
12. P1010 Missing Password
13. P06415 V+Vref 1 Out Of Range
14. P06515 V+Vref 2 Out Of Range
15. P0373 CKP Sensor Intermittent
16. P0107 Map Sensor Open/Low
17. P0108 Map Sensor High
18. P0374 CKP Sensor Synch Error
19. P1600 EFI Module Processor Internal Error
20. P1270 TGS Validation Error
21. P2107 EFI Module Processor Internal Fault
22. P2122 TGS1 Low/Open
23. P2123 TGS1 High
24. P2127 TGS2 Low/Open
25. P2128 TGS2 High
26. P2138 TGS Correlation Error (Twist grip sensor)
27. P0120 TPS1 Range Error
28. P0220 TPS2 Range Error
29. P0122 TPS1 Low
30. P0123 TPS2 High/Open
31. P0222 TPS2 Low
32. P0223 TPS2 High/Open
33. P2135 TPS Correlation Error
34. P2119 EFI Motor Throttle Body Range Performance
35. P2100 EFI Motor Circuit Open
36. P2101 EFI Motor Circuit Range Performance (Actuation Error)
37. P2102 EFI Motor Circuit Low
38. P2103 EFI Motor Circuit High
39. P2176 EFI Closed Position Not Learned
40. P1514 Air Flow Fault
41. P2105 EFI Forced engine shutdown
42. P1501 Jiffy Stand Sensor Low
43. P1502 Jiffy Stand Sensor High
44. P0572 Brake Switch Low
45. P0117 ET Sensor Low
46. P0118 ET Sensor High
47. P0112I AT Voltage Low
48. P0113I AT Voltage Open/High
49. P1351 Front Ignition Coil Driver Open/Low
50. P1354 Rear Ignition Coil Driver Open/Low
51. P1352 Front Ignition Coil Driver High/Shorted
52. P1355 Rear Ignition Coil Driver High/Shorted
53. P1357 Front Cylinder Combustion Intermittent
54. P1358 Rear Cylinder Combustion Intermittent
55. P0261 Front Injector Open/Low
56. P0263 Rear Injector Open/Low
57. P0262 Front Injector High
58. P0264 Rear Injector High
59. P0562 Battery Voltage Low
60. P0563 Battery Voltage High
61. P0501 VSS Sensor Low
62. P0502 VSS Sensor High/Open..
63. P1356 Rear Cylinder No Combustion
64. P1353 Front Cylnder No Combustion
65. P0444 Purge Solenoid Open/Low
66. P0445 Purge Solenoid High
67. P1475 Exhaust Actuation Position Error
68. P1477 Exhaust Actuator Open/Low
69. P1478 Exhaust Actuator Shorted/High
70. P0131 Front Oxygen Sensor Low
71. P0151 Rear Oxygen Sensor Low
72. P0132 Front Oxygen Sensor High
73. P0152 Rear Oxygen Sensor High
74. P0134 Front Oxygen Sensor Inactive
75. P0154 Rear Oxygen Sensor Inactive
76. P1510 EFI Limited Performance Mode
77. P1511 EFI Power Management Mode
78. P1512 EFI Forced Idle Mode
79. P0577 Cruise Control Input High
1. U1300 Serial Data Low
2. U1301 Serial Data High
3. U1016 Loss of ECM Serial Data
4. U1255 Serial Data Error
5. B1142 Smart Security System Internal Fault
6. B1135 Accelerometer Failed
7. B1136(HFSM) Accelerometer Tip Test Error
8. B1151 Bank Angle Sensor(BAS) Short to Ground
9. B1152 Bank Angle Sensor(BAS) Short to Battery
10. B1153 Bank Angle Sensor(BAS) High
11. B1154 Clutch Switch Input Short to Ground
12. B1155 Neutral Switch Input Short to Battery
13. B1134 Starter Output High
14. B1121(TSM) Left Turn Output Fault
B1121(HFSM) Left Turn Output Open
15. B1122(TSM) Right Turn Output Fault
B1122(HFSM) Right Turn Output Open
16. B1123(HFSM) Left Turn Output Short to Ground
17. B1124(HFSM) Right Turn Output Short to Ground
18. B1125(HFSM) Left Turn Output Short to Battery
19. B1126(HFSM) Right Turn Output Short to Battery
20. B1143(HFSM) Security Antenna Short to Ground
21. B1144(HFSM) Security Antenna Short to Battery
22. B1145(HFSM) Security Antenna Open
23. B0563 Battery Voltage High
24. B1131(HFSM) Alarm Output Low
25. B1132(HFSM) Alarm Output High
26. B1141(TSM) Ignition Switch Low/Open..
B1141(HFSM) Ignition Switch Low/Open
To reset the 2138 error I made sure that the my throttle was loose (star tension wheel not partially engaged) and in the idle position. Per info I was able to locate you cycle the ignition 4 times, you must make sure that you wait 3 to 4 seconds during each ignition ON cycle. After the 4 ignition cycles you should start bike and verify that problem has cleared.
After problem has been cleared you can go back into the diag mode and clear out the diag codes. The codes would not clear as long as the ECM was reporting the 2138 code on mine, but they cleared after the throttle reset. Has been a couple of days since I reset my throttle and all is well.
All of this info was available ont he web, just took me a while to find both parts. I do not take credit for the info but hope that it might assist someone and save you the time of tracking it down.
WFFW
Old 06-08-2009, 03:56 PM   #7 (permalink)
20538 is reading this now saying WTF is this?
I've had my check engine light come on for a few weeks. it started after turning on ignition to acc position to listen to radio while friend gasing up his bike. I did the check and found P1510 and P2138 codes. I just cleared them and will see how it goes when I go riding this Wednesday. busy next few days and tornado watch today. oh this is on a 2008 FLHX.
20538 is offline   Reply With Quote Quick reply to this message
Old 06-08-2009, 04:33 PM   #8 (permalink)
zoo
zoo wants to know Dino or Syn?
Nothing a ball-peen hammer can't fix.
zoo is offline   Reply With Quote Quick reply to this message
Old 06-15-2009, 03:46 PM   #9 (permalink)
Ok, went riding over the weekend and no more engine light after clearing the codes. thanks v-twin forum again. The source of the problem wound up being the ECM plug lock wasn't locked in. once it was locked and making a good connection the problem was solved.
