Removing Gas Tank from a Road King : V-Twin Forum: Harley Davidson Forums
Old 04-02-2008, 09:34 AM   #1 (permalink)
Rotoruder wants to know Dino or Syn?
Help!
I need to take the gas tank off of my 2003 RK Classic to take to the paint shop. I don't have a service manual and have never taken the tank off so I don't know how to do it, and if there is are any tricks or special things to watch out for. The bike is fuel injected. Advice is appreciated.
Rick
Rotoruder is offline   Reply With Quote Quick reply to this message
Old 04-02-2008, 09:28 PM   #2 (permalink)
bountyhunter wants to know Dino or Syn?
Who needs a service manual?
Obtain a short section of 5/16" ID hose.
Insert bolt in one end of hose and install hose clamp to ensure that end is plugged.
Cut clamp from one end of crossover hose beneath fuel tank.
Replace crossover hose on fuel tank fitting with open end of short hose & direct gas to container.
Purge fuel supply line of high pressure gas.
a. Remove the 15 amp fuel pump fuse.
b. Start engine and allow the motorcycle to run.
c. When the engine stalls, operate starter for 3 seconds to remove remaining fuel from fuel lines.
Remove fuel tank front mounting bolts from left and right side of frame.
Remove bolt to free rear of fuel tank from frame backbone.
Remove acorn nut from instrument console.
Raise instrument console and bend back flexible clamp on canopy to release main harness conduit.
Remove fuel level sender/fuel pump connector, 4-place Packard, at top of canopy.
bountyhunter is offline   Reply With Quote Quick reply to this message
Old 04-04-2008, 09:53 AM   #3 (permalink)
Many thanks Bountyhunter!
Old 03-05-2013, 03:03 PM   #4 (permalink)
tlyoungb wants to know Dino or Syn?
gas tank removal
How about for a 05 Electra Glide Standard with EFI? is there a step by step video anywhere on how to remove the gas tank? Or at least a step by step instruction with pictures.
That would be awesome.
tlyoungb
"[Motorcycling] stimulates that primal part of our brain that's isolated when we just drive from place to place in our cars."
tlyoungb is offline   Reply With Quote Quick reply to this message
