Ultra Com Port Pin Out... : V-Twin Forum: Harley Davidson Forums
Old 08-31-2007, 08:41 AM   #1 (permalink)
OLDBOY
Greglal's Avatar
Greglal wants to know Dino or Syn?
Can anyone verify if this information is correct. I want to try to build a couple of different mic setups for my ultra (Handheld, 1/2 helmet attached Mic only, etc.) and I found the following information. I am hoping someone can verify if the pin outs are correct for an 07.
Ultra Headset DIN Plug Pinout:
Looking at the 7-pin connector with the index groove in the connector at the twelve o'clock position, the bottom pin is #2. So clockwise from the index groove the pins are #6, #1, #4, #2, #5, #3, #7.
6 is the shield/ground (one o'clock position)
1 is the microphone input (three o'clock position)
4 is the microphone ground (five o'clock position)
2 is the speaker ground (six o'clock position)
5 is the left speaker positive (seven o'clock position)
3 is the right speaker positive (nine o'clock position)
7 is the handheld PTT (eleven o'clock position)
Greglal is offline   Reply With Quote Quick reply to this message
Old 08-31-2007, 09:29 AM   #2 (permalink)
This Space for Rent
kr70657 wants to know Dino or Syn?
Looking at the schematic in the 2007 touring model service manual I see the following
6 NC
1 MIC IN SHARED (-)
4 FRT MIC (+)
5 LFT HDSET SPKR (+)
3 RT HDSET SPKR (+)
7 PTT (on front connector), NC on rear connector
8 MIC SHARED SHIELD
Your numbering is consistent with the manual
What I show above as NC is blank in the manual, and has no connections on the bike side of the connector.
Kevin
2008 FLHTCU Vivid Black - Pure Stock
kr70657 is offline   Reply With Quote Quick reply to this message
Old 08-31-2007, 09:31 AM   #3 (permalink)
This Space for Rent
Originally Posted by kr70657
6 NC
1 MIC IN SHARED (-)
4 FRT MIC (+)
3 RT HDSET SPKR (+)
8 MIC SHARED SHIELD
Oops, missed one
2 HDSET SPKR SHARED -
Kevin
Old 08-31-2007, 09:32 AM   #4 (permalink)
bwana01's Avatar
bwana01 wants to know Dino or Syn?
I assumed (prby wrong) that a seven pin was a seven pin. J&M motorcycle audio, www.jmcorp.com 800 358 0881 has connectors/adapters for just about any configuration.
Bwana01
bwana01 is offline   Reply With Quote Quick reply to this message
Old 08-31-2007, 09:35 AM   #5 (permalink)
This Space for Rent
Pin 8 in my list is described as TAB in the manual.
Kevin
Old 08-31-2007, 12:33 PM   #6 (permalink)
jkane wants to know Dino or Syn?
Good luck getting a mic to work! Let me know if you do. I have a throat mic, an dtried a few combinations to get teh PTT to key up the mic, and it never worked right. Started to think that it was my radio. I don't have a hand mic to test it with to be sure. Really would like to get the mic to work and use the handlebar PTT with it.
jkane is offline   Reply With Quote Quick reply to this message
Old 09-06-2007, 07:12 PM   #7 (permalink)
CharlieChan's Avatar
CharlieChan wants to know Dino or Syn?
Is the throat mic wired into the 7 pin connector for console input, if so the hand PTT should work. I will be trying this next week when all my parts come in. Adding cb to a road glide and using the hand PTT with the plug for the headset/mic installed in the fairing.
CharlieChan is offline   Reply With Quote Quick reply to this message
Old 09-07-2007, 07:34 AM   #8 (permalink)
Not wired at all. It's a small mini plug. I was trying to build an adaptor that would go to the 7 pin H-D plug. Using alligator clips, I tried many combinations to get the polarity right. My voice never showed up on the other CB.
Sent a lot of emails back and forth with the manufacturer. Have their schematics and the HD ones. I am almost convinced I have a bad radio on my bike. Bought it used, and it didn't come with a mic so that is a possibility.
