The Cure Vent Plus: Anyone install it? : V-Twin Forum: Harley Davidson Forums
Go Back   V-Twin Forum : Harley-Davidson Motorcycle Forums > Model Specific Discussion Forums > Harley-Davidson Sportster
Old 01-23-2003, 03:05 PM   #1 (permalink)
KrustyTC's Avatar
KrustyTC wants to know Dino or Syn?
I was thinking of having The Cure Vent Plus by Creative Cycle Products installed in my 2002 883 Custom. It is supposed to fix the oil from the air cleaner problem once and for all. It installs underneath the valve covers.
What it is supposed to do is enlarge the drain hole and raise the oil dam so the oil has time to drain back into the engine instead of getting blown into the air cleaner. My dealer doesn't have any experience with this product at all so I'm hoping someone here can tell me whether it is worth having this thing installed or not.
I want to add the Screaming Eagle air cleaner but don't want to make the oil dripping problem any worse than it already is. It's not a huge deal with me because I don't do a ton of high RPM riding but I'd like to fix this so it's one less thing to have to worry about. Sucks having to remember to wipe out the air cleaner everyonce and a while.
I also don't think that just running a longer hose so the oil drips onto the ground is a "fix". It's just a band aid for a problem that shouldn't exist in the first place.
thanks,
KrustyTC
KrustyTC is offline   Reply With Quote Quick reply to this message
Old 01-23-2003, 04:17 PM   #2 (permalink)
rwb
rwb wants to know Dino or Syn?
I put it on my 1200. It mostly works except when the oil gets really hot or you ride at high RPM's for an extended period of time. I also put the SE aircleaner on at the same time. I've had drips only from the above mentioned problems. Around town I don't have any drips.
rwb is offline   Reply With Quote Quick reply to this message
Old 01-23-2003, 06:12 PM   #3 (permalink)
KrustyTC's Avatar
Thats the only time I have any problems anyway. High RPMs for a long period of time or really hot days when the oil thins out too much. I don't really have any problems with normal driving. Although it may reduce the amount of time needed in between wiping out the air cleaner.
Do you have any oil buildup in the air cleaner at all or only during high RPM really hot days?
later,
KrustyTC
Old 01-23-2003, 09:25 PM   #4 (permalink)
rwb
Only during high RPM really hot days. But then again my bike is black.
Old 01-23-2003, 11:06 PM   #5 (permalink)
Rscotts1 wants to know Dino or Syn?
Just purchased these from Lee Barnett, should arrive in a couple of days.
http://members.directvinternet.com/swanem/DSC01605.JPG
http://members.directvinternet.com/swanem/DSC01606.JPG
http://members.directvinternet.com/swanem/DSC01607.JPG
"This setup only works with the Screamin Eagle Airbox. If that is what you have I will send you the vented standoffs and specially bored and drilled bolts for 25 dollars. You will need to buy 3 ft of 3/8 fuel line tubing, a Tee connector, some clamps, and whatever you want to terminate the system with. This could be a PCV valve, or a crankcase breather filter or nothing. $25.00 a set."
Lee Barnett
2433 Osborne Dr
Norman OK 73069
LBarnett1@cox.net
02 883 XLH
Taxes paid
Forward controls/teardrop mirrors/HD grips/11" Progressive shocks/Cycle Shack slip-ons/Smoked lens covers/HD Badlander seat/Laydown license plate kit/SE air intake/re-jet
Rscotts1 is offline   Reply With Quote Quick reply to this message
Old 01-23-2003, 11:56 PM   #6 (permalink)
VincentH wants to know Dino or Syn?
That vent stand off system is exactly what I was envisioning in my head. Thanks for the info...now I wont have to engineer my own.
Vincent
2002 Road King EFI Luxury Rich Red Standard
2003 XL883R converted to 1200R using Buell Heads, Pistons, and Cams
1970 Triumph 650 Bonneville all original
VincentH is offline   Reply With Quote Quick reply to this message
Old 01-24-2003, 12:09 AM   #7 (permalink)
No problem VincentH, I happened upon this at www.Sportster.org which I frequent alot for different ideas. When I first saw the bolts/drilled spacers, I about crapped my pants!! Was exactly what I was look'n for. Can't wait till mine get here, already got the tubing/fittings (stainless steel) ready. Aloha.
02 883 XLH
Taxes paid
Old 01-24-2003, 12:29 AM   #8 (permalink)
Here is another link/pic of the bolts and spacers and what Lee did to them to make it work. Sorry I cannot post pics (too large), I do not have my phto/paint program running right now.
http://www.auffarth.com/nooil.jpg
02 883 XLH
Taxes paid
Old 01-24-2003, 02:51 PM   #9 (permalink)
KrustyTC's Avatar
To Rscotts1:
All that does is reroute the breather setup so the oil drips on the ground instead of going into the back of the air cleaner. That's a bandaid for the problem. I'm looking for something that will fix the problem.
thanks,
KrustyTC
Old 01-24-2003, 03:05 PM   #10 (permalink)
It may look like a "Band Aid" but I for one would damn sure like my scoot venting to the ground than out of the back of my Screamin Eagle filter all over the side of my flat black oil tank and up the side of my seat and pants!!
Vincent
Old 01-24-2003, 03:12 PM   #11 (permalink)
KrustyTC's Avatar
I totally agree with you, sorry if I offended you at all. I was just saying that if this product works and fixes the problem, then I won't have to have any oil dripping from my bike at all. Which is how it should be. "They all leak" isn't an answer we should put up with anymore.
later,
KrustyTC
Old 01-24-2003, 09:17 PM   #12 (permalink)
KrustyTC, you do not need to vent it onto the ground, you could simply rig up some kind of small catch can (could even be as small as a film canister) stuffed with foam or something. I agree with VincentH, if there is a product out there that (really) keeps the oil out of my SE air cleaner I am going to buy/install it in an instant!! So far from what I have read, practically NONE of the products out there will keep the oil out of your air cleaner, the only way to do this is to totally reroute those pesky breather lines.
02 883 XLH
Taxes paid
Old 01-24-2003, 10:05 PM   #13 (permalink)
Larry Burger wants to know Dino or Syn?
Hey Guys , Since I installed the Kuryakyn Hypercharger on my scoot I have'nt had a lick of the infamous oil drip like i had with the S.E. kit.
04 FXDI Silver, 03 883 Hugger
Larry Burger is offline   Reply With Quote Quick reply to this message
Old 01-25-2003, 08:53 AM   #14 (permalink)
KrustyTC's Avatar
That's my point though. This thing is supposed to eliminate the oil coming out of those lines to begin with. Then I wouldn't need to reroute the lines. Even if it just reduces the problem to the point where any oil that does come out of the lines is sucked into the carb like it's supposed to be it might be worth the cost. I think I'm going to have it done. Of course I won't be riding anytime soon here in Mass. with temps way below freezing. But as soon as I get this installed and get a chance to ride the bike I'll let you guys know how it worked.
later,
KrustyTC
