Take off both of your battery cables, clean all the contact surfaces (not just the battery side, but also the starter and ground mounts) with some rough sandpaper and resinstall (with hot + cable first, then the ground - cable). This should clear up your problem.
If this does not, you may have a problem with your ignition switch but is not likely.
Good luck.
Wes.
1990 FATSTER - 16" wheels front/back, Fat-Bob tanks/dash, Koni shocks, Ness taildragger fenders, Ness wide-glide billet trees, Storz steering dampener, PM calipers, full-floater rotors, SBS brake pads, Fat-Boy lights, 1200 10:1 pistons, Total Seal Gapless rings, Andrews V6 cams, Crane adj. pushrods, mod. CV carb., custom Ram-Air filter, Crane Single-Fire, Accel coils, Thunderheader (from Sonny Barger), Barnett Extra-Plate clutch, Balance Master, Jagg oil cooler, Spyke Krank Vent,....
