Diamond Bar ChoppersPowerstar SparkplugsSportbikeTrackGearCustom DynamicsDan Vance RacingMotorcycle.com Classifieds!Stainless Ride Specialty AccessoriesFuel Moto
GoFreeCreditReport
Old 07-31-2004, 03:29 PM   #1 (permalink)
timberz
Rear brake concerns
My son just bought a '96 1200 custom and I've noticed that the rear brake is very hard to get any braking from it. Pads & rotor are in good shape. The brake will stop the bike but you have to put a lot of leg into it to get the job done. Before we start tearing into the master I was wondering if someone had run into this problem and had a solution or something to start looking for. Thanks.
"Let those who ride, decide."
'02 Fat Boy
95", 10.5/1, Branch Heads
HPI - 51mm - K&N
TW55G - Crane rollers
Fueling lifters, oil pmp
DTT - V&H Straightshots
timberz is offline   Reply With Quote
Old 07-31-2004, 03:48 PM   #2 (permalink)
Bank Robber
Fangar is on a distinguished road
Check the rotor for lube (oile /grease). One time I got some leather protectant from my saddle bags on my rear rotor like a bafoon and experienced the same issue. You already checked the pads, you might have some air in the line, so a bleed might be in order.
Have you noticed that there is a lot of travel in the pedal if that is the case, that would lead me to believe there is a pressure, air, bleed issue. If it is hard, but does not stop the bike, then I would lean toward a grease / oily bad pad composition issue.
Good luck!
Fangar
2003 FXDWG Wide Glide
"You can't get there from here..."
Fangar is offline   Reply With Quote
Old 08-01-2004, 07:36 AM   #3 (permalink)
Boriqua is on a distinguished road
I know what you mean ... I cant lock up my back break. I guess I can if I use my heel but I havnet tried that yet. A bleed sounds like a good Idea. Think I will give that a try.
Alex
Boriqua is offline   Reply With Quote
Old 08-01-2004, 10:24 AM   #4 (permalink)
timberz
Good luck!
Fangar
Thanks for the info. We'll give both a try.
'02 Fat Boy
HPI - 51mm - K&N
