To all of this, i say.. HUH!?
First, i think if you getting your Carb rejected and Dyno-tuned (Which i not really needed on a Stock bike..), the filter is comming off. I dont even think they will charge extra for putting on the new filter on as they will have to remove the old one. then agian my dealer charges by Hr, so i dont know how your will do.
Also, if you must install it yourself, you will not be running lean.. Hell, i think the new Air Filter might help you even without the rejecting. Yeah you will get some poping and stuff, but nothing that will cause your motor to die in 20 miles. I mean you should see how HD sells these bikes stock in CA, they are almost un-rideable.
EDIT:
The more i think, the more i have a feeling a bike running hot means it running rich, not lean.. Lean would get you the popping and hard cold start problem.
I am Pakistani And No! I do not own a 7/11! And my NAME is not Apu!
