Hey Never,
So you want pulled back and higher up.. Well it can be done in more ways then one.
New risers is a good way if you want to keep the stock drag bars, or some mini-ape or things like that.
In all of that, just see how much does the new bar add to the lenght and you can find out if it will fit the stock wire. If you have to splice and add more wire, its not that bad. CC sells wire that is the same HD color so its all good.
Oh, and if the bars for for internal wiring, the turns sometime take more wire then if it was just out.. I was short by a few in bc of that, but thanks to some re working the connectors, i was able to get the in without a problem.
I am Pakistani And No! I do not own a 7/11! And my NAME is not Apu!
