Bad Ignition Module Symptoms? : V-Twin Forum: Harley Davidson Forums
Go Back   V-Twin Forum : Harley-Davidson Motorcycle Forums > Model Specific Discussion Forums > Harley-Davidson Sportster
Old 02-02-2004, 07:55 PM   #1 (permalink)
SportsHog wants to know Dino or Syn?
What would be the symptoms of a bad ignition module?Anyone had one go bad recently?Thanks for any info.
SportsHog is offline   Reply With Quote Quick reply to this message
Old 02-03-2004, 06:27 AM   #2 (permalink)
RandeeReid wants to know Dino or Syn?
I had one go bad last year. It acted like I ran out of fuel except that it cut out like right now. I was able to restart the motor before the bike even slowed down much and then it ran like crap all the way home. Once I got home it was fine. It would run sometimes for a couple of days before it cut out again, usually restarting fairly quickly. Since my bike is my daily transportation, I was trying to diagnose it while riding to work and school. When it started acting up, it acted like it was a fuel problem 'cuz if I feathered the throttle, I could nurse it home. I finally gave up and took it to a local indy shop and it turned out to be the ignition module.
RandeeReid is offline   Reply With Quote Quick reply to this message
Old 02-03-2004, 07:56 AM   #3 (permalink)
What mine is doing is when it is hot ..it turns over slower..and then cranks.It you let it cool for 5 minutes..it turns over normal.Sometimes it will backfire right before it starts.But it does not cut out when running.Actually it runs very strong.So i'm leaning toward a "tired" battery.Anybody else?
Old 02-03-2004, 08:05 AM   #4 (permalink)
Ed Y's Avatar
Bad coil is also a possibility. You also need to check all the battery, hot and ground wire connections. The service manual has a diagnosis procedure for the ignition module. They tend to fail in a variety of ways though, some slowly, others all at once. Start with the simple stuff first. Get the battery load tested too.
Ed Y
Retired Navy, MCPO
