Motorcycle.comAdvanstarMotorcycleShows
CycleGear.comLeslie Kay'sDan Vance RacingRRcycles.com
Motorcycle.com Classifieds!
Old 09-01-2009, 07:15 PM   #1 (permalink)
EVO883 is on a distinguished road
Talking modded 883 coughing through carb
Hey all, new to the forums.
1986 883 evo, andrews v4 cams, not sure about the pipes. I bought it off of my buddy's dad who said he could never get the carb dialed in. Well, I got a little curious and took the carb apart, found out he was running jets that were WAY to big, it would break up at around quarter throttle then come back. Put in smaller pilot and main jets and it SCREAMS, just now it has the "sportster cough" worse than ever. There's a needle adjustment for the main jet, its a thumb screw through the botttom of the bowl, not sure what it's for. If I can get the help from you guys it will be mucho appreciated , I want this problem solved!
Here's a pic of the bike:
EVO883 is offline   Reply With Quote
Old 09-01-2009, 07:22 PM   #2 (permalink)
Doof Bag
huckinfog's Avatar
huckinfog is on a distinguished road
Many times, a yost power tube is the first recommendation given.
Believe in all the good things,that money just can't buy
Then you won't get no bellyache, from eatin' humble pie
I believe in rags to riches, your inheritance won't last
So take your Gray Poupon my friend, and shove it up your as*.-Aerosmith
huckinfog is offline   Reply With Quote
Old 09-15-2009, 11:42 PM   #3 (permalink)
prospecting everyone has
1fast2liter's Avatar
1fast2liter is on a distinguished road
also carb couph is normal all though anoying it will never fully go away
99 flhtc 95"
p&p heads
screaming eagle pistons 10-1
sc cams "mild" soon to be 260's
sc igniton and coil and wires
44mm sc carb kit
fulsac true duals
samson rolled thunder slip-ons.
sc intake kit
coming soon
adj push rods
sc 260 cams
manual compression releases
accel wires
sc clutch kit
sc htcc heads or nrhs ported heads possibly dimond cut everything
1fast2liter is offline   Reply With Quote
Old 09-16-2009, 06:21 AM   #4 (permalink)
Iron Will
Hillside's Avatar
Continue to increase the pilot jet until it is gone, as it is too lean.
Scott
