Pro PadBub EnterprisesAdvanstarMotorcycleShowsBikeBanditFuel MotoMotorcycle-CommunicationDiamond Bar Choppers
Pro Pad
Old 08-17-2009, 02:59 PM   #1 (permalink)
sdailey5 is on a distinguished road
Another Virgin Question
OK, so I got awesome advice from dave on the "re-jet with new filter thread". Now I got a new problem. I just changed the petcock, new plugs, new wires, and new high flow air filter...
Now I have the carb backfiring? into the air cleaner housing. Not sure it is a backfire though, because there is no "popping" sound. It sounds more like somebody spitting. It sounds like a sharp,short exhale of air coming out of the carb and into the air cleaner.
This is happening on a 1999 883 sportster. I never had this happen before I changed out the parts listed above. Any suggestions? I need some help guys. Thanks.
sdailey5 is offline   Reply With Quote
Old 08-17-2009, 03:01 PM   #2 (permalink)
Oh yeah, it tends to happen only in gear and right off of idle, low RPM's only. I feel a power surger, or lack thereof, when it spits.
Old 08-17-2009, 03:18 PM   #3 (permalink)
HRLYDeuce's Avatar
HRLYDeuce is on a distinguished road
I have the same thing happen on my 2002 Deuce on occasion, it's more of a sneeze, not a miss just off idle, and like you, low RPM's only! But mine is EFI!
Its not how fast you go, but how good you look!
2006 Electra Glide Classic
So far:
Stock "88"
PCIII
"Zippers" Max Flow A/C
FullSac Tru Duals & Mufflers
Amsoil in all three holes!
More changes coming!
HRLYDeuce is offline   Reply With Quote
Old 08-17-2009, 03:22 PM   #4 (permalink)
frankysfree is on a distinguished road
sounds like you might have an intake leak. take carb cleaner and spray on your intake seals(the two that seal between head and intake, and the one from carb to intake) make sure not to get it near the aircleaner as it will give you false reading. if it changes the rpm when sprayed on the intake you have a leak.
frankysfree is offline   Reply With Quote
Old 09-30-2009, 09:31 AM   #5 (permalink)
JDRAKE4200 is on a distinguished road
Sounds like a carb fart. IF you dont have an intake leak, you need to rejet because you are running lean and that is BAD!!! if you have an EFI, you need to remap. That is why I have a carbed bike. EFI is reliable, but a lot more money to tune.
JDRAKE4200 is offline   Reply With Quote
Old 09-30-2009, 12:21 PM   #6 (permalink)
strokerjlk's Avatar
your a little lean now.
when I ran carbed bikes I would run 2 set of jets.
one set for spring and fall and 1 set for summer .just me though as I couldnt stand the spitting carb.
07 ULTRA
S&S 106 CI
Big Boyz heads
D&D Fatcat
Hillside/Green A/C
SE 204
GARMIN 2610
3 GAL. AUX FUEL CELL
IBA# 31913
BBG
1566 MI 23 HR'S
Thomas Jefferson
