Leslie Kay'sCustom DynamicsDiamond Bar ChoppersAdvanstarMotorcycleShowsBikeBanditRRcycles.comPro Pad
Old 08-06-2009, 09:15 PM   #1 (permalink)
HepCi is on a distinguished road
Rear fender reflector question
So I want to pull these bad boys off, it was easy getting all but these 2 off...
Anyone have any details on a fast easy way to pop them off?
any help would ROCK!!
HepCi is offline   Reply With Quote
Old 08-07-2009, 08:34 AM   #2 (permalink)
fatbillscustoms
FatBill is on a distinguished road
Well placed hammer shot is the fastest!
Well placed hammer shot is the easiest!
Hair dryer / heat gun is the smartest!
'04 Fatboy
518 Chubby Wild 1's
SS Braided Cables
Chrome front end
Chrome rear end
Nacelle w/ passing lights
LePera Solo seat
Stage 1 EFI
V&H BS Staggered
PCIIIusb
Progressive airtail
Z Pads (Lyndall Racing Brakes)
Black/Blue Devil Tails
FatBill is offline   Reply With Quote
Old 08-07-2009, 11:33 AM   #3 (permalink)
mooooving out!
route66paul's Avatar
What about the ones on the forklegs?
43%er
Bi-polar and loving it!!
Bi-polar and hating it!!
95" w/ KB pistons (flattops)
HQ575 cams
Atwood's Road Warrior Heads
.030 head gasket
SuperTrapp Supermeg 2in1
"43" points cover
TRW rear mount
obligatory Baisley Spring
Just sayin..........
Old 08-07-2009, 12:09 PM   #4 (permalink)
Custom Painter
kustom_flames's Avatar
Guitar string or fishing line is usually a good way to separate emblems/reflectors from the adhesive tape. You can then use a degreaser or goof-off type product to remove the adhesive residue left behind. If you use the string, be careful not to dig into the clear.
Old 08-07-2009, 12:26 PM   #5 (permalink)
Karsten is on a distinguished road
Yup, what he said......Fishing line will pop them right off both the fender and front forks. Them while you are at it take some Citrus Strip to the front lower forks to remove the pitted clear coat and polish the heck out of them.
You can also find Goo Gone at Walmart in hte Piant Dept for alot less find the little cans of Goof Off at Home Depot.
Looks a lot cleaner without the reflectors in my opinion.
Karsten
Karsten is offline   Reply With Quote
Old 08-08-2009, 10:53 AM   #6 (permalink)
I dont think you guys read my post at all!
ALL of the reflectors are off the bike....i am left with the 2 rear ones like explained in my post.
I used dental floss for them all but now i cant get the 2 rear ones because they are set into a piece of plastic and i cant get floss or string into where i can pop them off at....I think i will figure it out.......
Thanks anyway
Old 08-08-2009, 11:08 AM   #7 (permalink)
Custom Painter
You didn't mention anywhere they were recessed in or whatever. Why don't you take a closeup pic and post? If they are in that far then go to a FLAPS and buy a product called grafiti remover or something like that....will also say bumpersticker remover on it. Comes in a small spray can with a little straw (like WD40) and you might be able to really work that in and underneath it. Let it sit for 5-10 minutes and see if you can work off the piece by hand or maybe it will loosen enough to get a small screwdriver or something under it to pry it off. Can the whole plastic piece be removed? I am workin on an 07 sporty right now and the rear fender I got did not have any reflectors on it or did it even look like there were any to begin with, so maybe the whole thing can come off...
Old 08-08-2009, 11:10 AM   #8 (permalink)
lostinafog's Avatar
lostinafog is on a distinguished road
you still got reflectors...
how quaint, how 'old school'...
thats a novel new idea...
lostinafog is offline   Reply With Quote
Old 08-08-2009, 04:59 PM   #9 (permalink)
This was the comment I ment... I am new to HD cycles so i figured all sporty's had rear fender reflectors like this.
I guess I didn't do much searching other than on '09 models.
It looks like the whole piece could come off but like i said, I am new to motorcycles and dont want to pop bolts out when it looks like it deals with the frame work!
I will see if i can get some close up pics of under, inside, and outside on monday or sunday night since I wont be home until then. I am trying to keep the flectors in good shape also for resale in case someone is super picky!
Also I don't care if everyone else is doing it, its not me jumping on the bandwaggon or being "uniqe"....It's all about black!
Old 08-08-2009, 07:06 PM   #10 (permalink)
citified is on a distinguished road
on the Ns you have to unbolt the bracket from the fender and cut it off, the reflector is attached to the fender rails.
citified is offline   Reply With Quote
Old 08-10-2009, 01:17 AM   #11 (permalink)
Highwayman's Avatar
Highwayman is on a distinguished road
WHen I siwtched my C to a N rear, I took my dremel and cut off those unsightly reflectors, then painted the aluminum black where I cut it.
http://www.v-twinforum.com/forums/image.php?type=sigpic&userid=70756&dateline=1245213424
Highwayman is offline   Reply With Quote
Old 10-16-2009, 08:01 PM   #12 (permalink)
Demon2Alpha's Avatar
Demon2Alpha is on a distinguished road
From looking at the service manual, it seems like you would have to remove the rear fender to be able to access the reflectors.
Demon2Alpha is offline   Reply With Quote
Old 10-16-2009, 10:52 PM   #13 (permalink)
hbmc's Avatar
use a hair dryer get the glue hot or warm on the reflector and should just peel off. I also use lighter fluid to get the glue off. No issue with the paint.
1991 flstf 'fat-boy
2-1 White "E-pipe"
29 tooth Andrews pully
