Originally Posted by claydbal
thanks, so its taking the oil drains and using them as a portal to an oil cooler?
An old thread I know, but if was not answered, the XR1200 heads have extra oil passages milled in them. There is an additional oil feed that fills the heads with oil, draws off heat and drains it separately out to the oil tank. This oil flow is completely separate from the top end oil flow through the rocker arms, and it is an effective means of pulling down the heat in the heads. The heads also require a different head gasket because of how the oil passages are formed. Maybe if HD did this on the CVO 110s, they wouldn't be having such a problem with the heads and cylinder liners...
