tank sealer??? : V-Twin Forum: Harley Davidson Forums
Go Back   V-Twin Forum : Harley-Davidson Motorcycle Forums > Model Specific Discussion Forums > Harley-Davidson Sportster
Old 06-18-2009, 08:32 PM   #1 (permalink)
trbomax's Avatar
trbomax wants to know Dino or Syn?
tank sealer???
Ive got a lot of light grey flakes and chunks in my gas tank (89xlh1200). It looks like a sealer. Did HD use sealer in tanks,or have I got a "special" issue? Stock tank,no crash damage,original paint .
I'm just a crusty old fart who's stuck in the 60's,and likes it.Remember,loud pipes and horns rock!
trbomax is offline   Reply With Quote Quick reply to this message
Old 06-18-2009, 11:33 PM   #2 (permalink)
Buddy Seat's Avatar
Buddy Seat wants to know Dino or Syn?
Yep, HD was coating the tanks till about 2005 & gray was one of the colors they used.
If your is flaking off, time fer some help removing the stuff..& recoating it to prevent rusting..
This is what I find is very good & durable..
http://www.por15.com/Fuel-System-Res...n/products/12/
Bud
Buddy Seat is offline   Reply With Quote Quick reply to this message
Old 06-19-2009, 06:46 AM   #3 (permalink)
coasty's Avatar
coasty wants to know Dino or Syn?
JP Cycles also sells good tank coating, my 03 had some flakes but when I inspected it all was well. It appeared to be some excessive left overs in the tank.
Coasty
coasty is offline   Reply With Quote Quick reply to this message
Old 06-19-2009, 09:58 AM   #4 (permalink)
trbomax's Avatar
Well,if its not leaking,I really cant see a reason to have it coated. Maybe I'll give it the "ball bearing shakeup treatment",or maybe I'll just ignore it this year.Got to wonder why they did it in the first place though.
Old 06-20-2009, 12:37 AM   #5 (permalink)
Highwayman's Avatar
Highwayman wants to know Dino or Syn?
POR-15 you will never have another problem with your tank
http://www.v-twinforum.com/forums/image.php?type=sigpic&userid=70756&dateline=1245213424
Highwayman is offline   Reply With Quote Quick reply to this message
Old 06-20-2009, 01:13 AM   #6 (permalink)
Average Dude
YankeeBob's Avatar
YankeeBob is reading this now saying WTF is this?
POR-15 is the bomb!!
Deut. 23:12-13
YankeeBob is offline   Reply With Quote Quick reply to this message
Old 06-21-2009, 01:00 AM   #7 (permalink)
Buddy Seat's Avatar
So it doesn't RUST..(Hello).... especially with the ethanol blends, they tend to attract more moisture & the tank bottoms will rust first as water is heavier than gas.
Bud
Old 06-22-2009, 04:44 AM   #8 (permalink)
Krayven Sumhead wants to know Dino or Syn?
All that excessive gray stuff plugged up my fuel filter on my '05.
Krayven Sumhead is offline   Reply With Quote Quick reply to this message
Old 06-23-2009, 02:55 PM   #9 (permalink)
tguil wants to know Dino or Syn?
The short story: The fuel tank on my 1995 Sportster was full of sealer crud which resulted in major carb work as well as a thorough cleaning of the fuel tank.
According to the techs, the Motor Company says not to reseal the tank. Just make sure that it is well-cleaned. Then keep the tank full to prevent rust from forming.
How did they clean the tank? Almost four hours of shaking nuts, bolts, etc.in the tank in a water solution and then rinsing the residue with a high pressure wash.
I guess this is a problem with quite a few Harley tanks of this vintage.
Tom
Two Harleys and a Ram Hemi 4X4 -- life is good.
tguil is offline   Reply With Quote Quick reply to this message
Old 06-24-2009, 01:43 AM   #10 (permalink)
Buddy Seat's Avatar
Tom
Guess what Tom, even with a full tank over time a bare tank will rust, generally on the bottom first..
The ethanol blends attract moisture & since water is heavier than gas that's where it goes..
My 94 & 97 still have the OEM coatings in em, & good shape as well.. Some have problems, some don't..
But the ethanol blends are harder on the coatings. Por 15 is super..
Bud
Old 06-27-2009, 08:59 AM   #11 (permalink)
The Sportster Service Manual suggests the procedure followed by the techs who worked on my tank. It does not recommend resealing the tank. I don't use gas with ethanol blends -- ever. And because I don't ride the Sportster as often as my Super Glide I make sure that the Sportster's fuel always has fuel stabilizer mixed with it. So far it has been OK -- three years since the tank was cleaned
Tom
