Originally Posted by claydbal
35 miles to the tank? i would think you would foul plugs before you got out of the driveway. had severl hotrod ironheads and would look for gas when odometer hit 80 miles. i dont know how it runs long enuff to tell MPG. time to blueprint everything if you gonna keep that tranny eater.
You are correct - my thoughts exactly - and yes it did foul a plug. Here is the outcome. Found lots of trash in the Accellerator adjuster of the S&S shorty E carb. Also found bowl height adjustment way out. Bottom line is the gas was probably overflowing out the vent line and remainder going around pistons into gas. Changed the oil, Rebuilt carb and set bowl height correct. Also made a mental note to NEVER leave petcock open when Bike is not running. Running fantastic now with no massive gas use.
Sam
