883/1200 Conversion : V-Twin Forum: Harley Davidson Forums
Go Back   V-Twin Forum : Harley-Davidson Motorcycle Forums > Model Specific Discussion Forums > Harley-Davidson Sportster
Old 11-26-2008, 05:18 PM   #1 (permalink)
MarkCrain wants to know Dino or Syn?
883/1200 Conversion
I did a search and saw a lot of info on the conversion. I got the dished pistons and went with an andres 4N stock carb. Anyone else run this set up? What did you jet the carb with? I believe mine has a 45 intermediate jet and when I screw in the idle mixture I can go all the way without the engine quiting.
Mark Crain
MarkCrain is offline   Reply With Quote Quick reply to this message
Old 11-28-2008, 05:40 AM   #2 (permalink)
richard head wants to know Dino or Syn?
the 45 should be in the idle pilot ."small brass tube screwed into carb body " only accessable with float bowl removed.45 should be about right .if you can close your idle screw, fuel is leaking into throat .Did you use a new "tiny" o-ring on top of the accelerator pump nozzle .Either that or something in needle valve ,or float to high.Another possibility is you have butterfly open too far and it's actually sucking fuel up the Main.You can look down the throat and see if it's sucking fuel up the main(tube the slide needle goes into) ."tip" use a mirror .That way if it spits back you don't burn your face
richard head is offline   Reply With Quote Quick reply to this message
Old 01-25-2009, 06:44 AM   #3 (permalink)
prophet's Avatar
prophet wants to know Dino or Syn?
Let us know how your set up performs...specifically with the 4N. A friend of mine is looking to step up the cam on his 1200 to that cam. Also, what exhaust are you using?
2010 FLHTK, SE-204/1.725 rockers, SEST, VH Pro-Pipe, Roland Sands Breather, Arnott Air Suspension.
prophet is offline   Reply With Quote Quick reply to this message
Old 01-25-2009, 05:41 PM   #4 (permalink)
DILLIGAF
RattFXR wants to know Dino or Syn?
I ran N4's in my 93 1200 with KB pistons and a S&S E. That bike came alive! It would out run 600 riceburners to about 75-80. And I had the bike at 136 and still was pulling, but a car pulled out in front of me down the road. I didn't do any ignition work, and ran drag pipes. You might be a little hinder by the heads, I can't remember if the 883 had the same size valves as the 1200. But you get the off line advantage due to your smaller tranny pulley.
RattFXR is offline   Reply With Quote Quick reply to this message
Old 01-25-2009, 06:10 PM   #5 (permalink)
arctic_mp7 wants to know Dino or Syn?
Built a bunch of those and put a Super E or 42mm Mikuni on them and they always ran great.
2012 Red with Flames FXDWG 113 Race kit
2011 Sedona Orange FLHX 103 stage II
Ultima 200 Rigid
DNA Springer
EVO motor, EV 46 cam, little bit of headwork and
42 Mikuni
Ultima 6 speed
2" belt drive
Retired Soldier (28 years of work), Now a Full time Technician (30 years & a lifetime of passion) (I am now growing my hair long)
arctic_mp7 is offline   Reply With Quote Quick reply to this message
Old 01-25-2009, 06:33 PM   #6 (permalink)
The great camel toe escap
1fast2liter's Avatar
1fast2liter wants to know Dino or Syn?
the older 883s ran a different head design then the 1200's.. the n4 cam is about the same as a stock xb buell cam. and with the xb style heads would make awsome power...
if you decide to keep your 883 heads p&p them if you got the money ideally pick up a set of xb heads or 2004 up sportster 1200 heads(same as the xb) and bore your 883 cyclinders out to a 1212 wich is like .040 or so... and i use the stock carb on mine 1242cc's 45 slow 170 main... and you will loose low end with drag pipes or a straight pipe period.. 2-1 is the best pipe if you want all out performance.. i had bissani pro streets on mine and felt the difference between vance and hince short shots......
1fast2liter is offline   Reply With Quote Quick reply to this message
Old 01-25-2009, 06:38 PM   #7 (permalink)
with n4 cams 1200 kit and stock 883 heads youll get about 74 hp or so with stock pipes and ignition.... youll wanna look at doing a sc intake or something along those lines...
Old 01-30-2009, 02:55 PM   #8 (permalink)
lloyd3015 wants to know Dino or Syn?
I was wanting to know if anyone knows where to get info on part numbers for a set of heads? Front head part# 16874-02y and rear head part# 16877-02y . Was told from a '04 Sportster. Any info would be great. Thanks
lloyd3015 is offline   Reply With Quote Quick reply to this message
Old 01-30-2009, 07:04 PM   #9 (permalink)
Try flatops, with a valve conversion and N-8's!!!!!!!!!!!!!
That really gets 'em running.
Old 01-30-2009, 10:12 PM   #10 (permalink)
what kind of valve conversion? n8s are a good cam but youll make all your power in the upper rpm's.....
as far as the other question how to tell if you got the newer style heads.. the easiest way to tell is by looking at the valve springs.. if their beehive style then you got the newer style heads.... if they dont have a beehive spring and are blackheads no high lighted heads with a single wire coming out of the rear head then they are thunderstorm heads...
