12-29-2006, 07:13 AM
Rear wheel removal question 04 Fatboy
I have an 04 Fatboy with stock exhaust. I need to remove the rear wheel to replace and upgrade the rear drive sprocket with a nice shiny one.
Will I need to remove the exhaust to get the wheel off and can anyone give me some tips on getting the wheel aligned and proper tension on the belt when I reinstall it? I have about 5000 miles on the bike and I would assume that the belt is still ok but I will take a look when I get it off. The tire still looks like it has a lot of life left in it as well. Thanks in advance for any advice.
Rob
12-29-2006, 09:17 AM
There was a wheel removal topic by 8-ball that had everything you'd need to know. If I have time I'll look for it. His is a touring bike, not a softail, but I think the steps are basically the same.
Edit. It starts at page 5 of this thread. http://www.v-twinforum.com/forums/sh...ad.php?t=91260
Engine [sic:motor] by Otto
12-29-2006, 09:56 AM
ovanay elinquentday
Ok I'll say it - the manual is a great help, if you are starting out unsure.
Other than that, yes the pipes will need to come off in order to slide the axle out. To align the wheel you can measure from the swingarm pivot bolt to the axle center on both sides, making sure both sides are equal. And if you've never hand checked the belt tension (get a feel for it before you pull the wheel), the little belt adjuster tool is a big help. Alternately, you can grab the belt by hand and twist it clockwise. If you can twist it to about 11 o'clock (not quite 90 degrees), it's about right. It should twist almost vertical, but not quite. Aside from a good torque wrench, you'll want to put some anti-seize on the axle while you have it out.
03 Fat Boy
Slammed rear
More Chrome
09 XR1200
A few gewgaws - no chrome
Tune by Phaedrus
John Bernard Books
43+ HP / 43+ Ft-lbs
12-29-2006, 01:21 PM
Ironbutt
Originally Posted by GPO03FatBoy
Ok I'll say it - the manual is a great help.
Great help is an understatement. I would say it is a necessity. Oh, and NEVER ever twist a belt. Twisting motions can damage the belt fibers and weaken the structure leading to premature failure.
Current bikes in the stable:
2009 Street Glide
2003 Heritage Softail Classic
12-29-2006, 01:22 PM
Jack ***
Leave the axle adjusters alone. You can get the axle out, change the pulley, and put it back together without moving the alignment or belt tension. It's easy.
I don’t know of one Muslim or Hindu who came over on The Mayflower or fought in The Revolutionary War and I don’t believe that we should have to change the customs of our country to accommodate their ways.
I believe that the official language of America is English and that the people who come here should be required to learn how to speak and write it and not the other way around.
Charlie Daniels
12-29-2006, 05:33 PM
I do have the manual and plan to use it. I took a brief look in there the other day but there wasn't all that much information about the rear tire removal, unless I missed something. I will take another look but I like to get tips from the guys here who have been down the road already and maybe have some good advice that would otherwise not be printed in the manual. I do like the idea of pulling the axle without loosening the adjusters. I would never think that would work and I'm sure that it's not in the manual.
12-29-2006, 05:47 PM
ovanay elinquentday
It's not that bad a job. With a lift you can do it solo by raising the bike off the wheel and lowering it back on during install. Just take care when installing the brake mount as you put the wheel back in. You'll want to make sure you get it set back on the locator tab on the frame. I prefer to back off the adjusters. It takes the tension off the belt and makes it easier for me to locate the wheel to align the axle. If you are certain the axle is aligned now, you could count threads and simply dial the adjusters back to the same point. Personally I have a belt tension tool, but a number of good mechanics just give the belt the hand twist to check tension. Between giving it a twist once a year to check tension, and running it excessively tight or loose, you'll end up with far more belt stress by running it out of adjustment. FWIW.
03 Fat Boy
Slammed rear
More Chrome
09 XR1200
Tune by Phaedrus
John Bernard Books
43+ HP / 43+ Ft-lbs
12-29-2006, 05:48 PM
you could mark the top of the adjuster bolts with a Sharpie
then back off both sides the equal amount of full revolutions
Once you reinstall , tighten both sides the same amount of revolutions back to where the Sharpie mark started
12-29-2006, 09:54 PM
The alignment procedure is so simple, why worry about counting threads or making marks? All the manual says to do is measure from the center of each swingarm bolt to the centers of the axle. The measurements need to be within 1/32" of each other with proper tension on the belt.
Obsolete 06 FLHTC
Ridden in the rain
Scratched Tour-pak
Additional parts that contribute to a smile
"The things that will destroy America are prosperity-at-any-price, peace-at-any-price, safety-first instead of duty-first, the love of soft living, and the get-rich-quick theory of life." --Theodore Roosevelt
12-29-2006, 10:18 PM
Thanks for a lot of good ideas. I will be getting the the belt tension tool. <p>
What's the deal with 43?
12-29-2006, 10:30 PM
Long story; start here.
Obsolete 06 FLHTC
Ridden in the rain
Scratched Tour-pak
| Sponsored Links |
