Bank Angle Sensor : V-Twin Forum: Harley Davidson Forums
Old 09-01-2006, 01:33 AM   #1 (permalink)
henry86040 wants to know Dino or Syn?
Bank Angle Sensor
I have a heritage softail classic. I am trying to find the bank angle sensor on my bike and I do not knwo where to find. Is there any way that one of you guys could tell me where it is at? Thank you for any help.
henry86040 is offline   Reply With Quote Quick reply to this message
Old 09-01-2006, 02:17 AM   #2 (permalink)
hijackak's Avatar
hijackak wants to know Dino or Syn?
I believe the Bank Angle Sensor is inside the TSSM. If it goes bad I believe you have to replace the entire unit. On a softail this should be behind the plastic fender panel forward of the rear wheel.
hijackak is offline   Reply With Quote Quick reply to this message
Old 09-01-2006, 10:49 AM   #3 (permalink)
road_king's Avatar
road_king wants to know Dino or Syn?
road_king is offline   Reply With Quote Quick reply to this message
Old 09-01-2006, 07:24 PM   #4 (permalink)
springer-'s Avatar
The Bank Angle Sensor should be a small black sensor with a 3 pin connector and only 1 bolt holding it on. I do not know the exact location on your year and model but I would suspect it is behind the access panel covering the inside of the swing arm. You should be able to remove 2 bolts from the bottom of the access panel and then lift it slightly to release the top. You may have to remove the right side saddlebag to do this. You may have to bend the fender in towards the tire a little in order to lift it. I don't mean bending it so there is a crease, just a little for clearance. Removing the rear tire will make this considerably easier.
I Highly recommend you get the factory service manual as it will spell out every step.
Check out Ride of the Month
207-621-8089
