Rear axle torque tech questions
Question 1:
The rear axle torque spec on my '04 FLSTCi is 60-65 ft lbs. If I tighten it anywhere in that range, I can't align the castle nut with the cotter pin hole. I set it to 55 ft lbs and can get the pin in. I know not to exceed 65 ft lbs. Are there any problems with leaving it at 55?
Question 2: I have the chrome swing axle covers (part #48112-00) that are secured by the axle adjuster lock nut. There is no way (that I can see) of holding the adjuster bolt in place while tightening the lock nut. The bolt tends to turn (loosen) as the nut is tightened, which I'm sure is going to allow the belt to loosen as I travel. My guess is about 1/2 turn, which is pretty substantial in terms of belt tension. Any idears or techniques or should I not even worry about it?
Can you hear me now?
