The extra wire is stashed in a loop that can be reached via the back fender. At the inside front of the rear fender is an access panel. Remove it, cut the cable ties securing the wire loop inside that hole, pull the loop loose, then pull the harness out the front of the frame while someone else feeds it into that hole in back. it helps to have the rear suspension unloaded to reach up between the wheel and fender.
AustinFXDWG
2005 FLTRi Road Glide - 95", SE Flat-tops, SE-AC, SEPro Slipons, Bassani Power Curve True Duals, Dynojet PCIII, HD Oil cooler, Mustang Touring Solo saddle, Fog Lamps, and HogTunes Speaker. Now we';re cruisin'...
