07-29-2012, 04:58 AM
#1726 (permalink)
Ghostrider, your bike look awesome. I am about to start modifying a freight train nacelle for my 2012 deluxe. Do you have any advice? I want to keep the passing light bar also.
Sent from my Motorcycle iPad app
07-30-2012, 06:56 AM
#1727 (permalink)
You shouldn't have to modify the Nacelle to fit your bike if you are using HD #67907-96C. As far as the passing lamp bracket goes, you'll need to grind down the mount standoffs. I had to grind about 3/16" off of the top two and about 1/8" off of the bottom two.
MM Orphans Friend Lodge #17
Never Take a Knife to a Gun Fight!
2011 FLSTN
08-02-2012, 07:13 AM
#1728 (permalink)
Thanks for the advice mate.
08-13-2012, 08:40 PM
#1729 (permalink)
I'm thinking of running a detachable fairing, any pro's or con's on the reckless?? Also which speakers sound the best, four round or two 6x9"s...
08-24-2012, 09:26 AM
#1730 (permalink)
Location: Virginia/ North Carolina. Depends on the week.
OK folks here's a tire question for ya, I'm in need of yet another rear tire, same Ole story, only about 7-K outta my stock Dunlap's. I'm staying with the wide white walls so my tire choice is limited, what are you running on your Deluxe and whats your avg miles ??? And yes I check tire pressure several times a week and it stays within a 38-40 lbs radius. One up 99% of the time.
08-24-2012, 10:04 AM
#1731 (permalink)
Thanks! I needed that.
While I got the best mileage out of the stock Dunlop (over 10K on the rear) I just don't care for their handling. Tried Avon Venoms and while handling was great, due to there very soft compound I only got about 6K from the rear. I'm now on my first set of Metzler 880 and they also provide much better handling than the Dunlops. There is currently 6K on the rear and still a fair amount of tread left. I'm hoping to get at least 8K from them.
I just wish Dunlop would produce the E3 or the D407/D408 in sizes and a WWW for the Deluxe and other Softails. They handle way better than the stock D401/D402 and still get great mileage.
"Age is a case of mind over matter. If you don't mind, it don't matter." Satchel Paige
95" Bore by Zippers - Wiseco 9.5 Pistons - T-Man StageII Heads - Andrews 37G Cams - Stock Crossover Dual Headers Samson Fishtail SlipOn's - TTS Mastertune - Build and Dyno by JD's Cycle Works
HP=98.03 - TQ=102.14 Uncorrected
HP=93.36 - TQ=97.27 SAE Corrected
Cost of build, about right. Value of grins, PRICELESS!
08-24-2012, 10:32 AM
#1732 (permalink)
My thoughts exactly Scabby, Im tired of low miledge tires that cost the same as my truck tires!
11-28-2012, 08:09 PM
#1733 (permalink)
Here is picture of my lady's bike. We have enjoyed making modifications along the way. Chrome hand controls 1 1/4 inch bars and SS cables going on next.
12-01-2012, 07:19 PM
#1734 (permalink)
Hey guys im new to the forum.
Here's a few pics of my 08 Deluxe:
Handlebars n risers are next on the list.
12-02-2012, 12:40 PM
#1735 (permalink)
thought about bags for my 2012 but addeds few rear chrome pieces instead...for now. Just bought a Uniq classic edition audio system and found out (lookin at manual) that I have to connect to a body control module instead of an accessory wire...well thats what the dealer said I should do. So I bought an HD update kit. We"ll see. Any suggestions ?
12-03-2012, 02:27 AM
#1736 (permalink)
Apparently my post from over 30 hours ago is still waiting to be approved by a moderator. (Pics of my Deluxe)
Is this normal?
12-26-2012, 06:56 PM
#1737 (permalink)
Squidly Do Right
12-26-2012, 10:50 PM
#1738 (permalink)
The 'batwing' is a different look.
12-27-2012, 12:04 AM
#1739 (permalink)
 :Hello all,have a denim fatboy lo a lot of black powder cote, almost nothing shiny any more.thinking of fat daddy 50 spoke wheels in flat black possibly wide white walls. Any thoughts/opinions appreciated
12-27-2012, 07:43 AM
#1740 (permalink)
I like the batwing, I'm really needing bigger saddle bags though, I want hard bags for sure, planning a trip to Sturgis this year and will need as much room as possible, these factory bags just ain't it !
| Sponsored Links |
