Clutch Failure? : V-Twin Forum: Harley Davidson Forums
Old 04-19-2017, 09:25 PM   #1 (permalink)
Bonn85635's Avatar
Bonn85635 wants to know Dino or Syn?
Clutch Failure?
SO, I was sitting at a red light the other day and all of a sudden my clutch handle just released and it stalled the bike.
There is an inch of play in the cable now and the clutch doesn't engage. No funny noises coming from anywhere.
I just installed a new cable a couple months ago, changed all the liquids in all cases and followed the adjustment procedure by the book, the real book, not a wanna be book.
I drained the transmission today, removed the trans cover to take a look. I originally thought the cable end had snapped off inside the trans case, not. It's fine, as are the throwout and bearings and clutch rod, all look very serviceable.
Anybody have a similar issue? I am draining the primary right now so I can take a look at the clutch pack, maybe tomorrow if I get time.
What does the forum recommend for a replacement clutch if I need one? The bike only has 8200 miles on it. Or possibly the pressure plate gave up the ghost?
Bonn85635 is offline   Reply With Quote Quick reply to this message
Old 04-19-2017, 10:01 PM   #2 (permalink)
Misters's Avatar
Misters wants to know Dino or Syn?
Sounds like the cable housing was not seated at all the connections...now it is.
http://www.jerseyh-d.com/hd/2008/Sof...g?maxwidth=799
Try adjusting the clutch and cable again.
https://youtu.be/gQ1D_1A9ds4
Misters is offline   Reply With Quote Quick reply to this message
Old 04-19-2017, 10:23 PM   #3 (permalink)
ecir45's Avatar
ecir45 is reading this now saying WTF is this?
What year bike? When mine did that the clutch hub moved off the taper shaft. When you pull the outer primary and give the clutch assembly a shake.
ecir45 is offline   Reply With Quote Quick reply to this message
Old 04-19-2017, 11:01 PM   #4 (permalink)
Bonn85635's Avatar
I don't think it was a loose clutch cable. It seemed to work fine the last 100 miles or so.
My scooter is a 2008 Rocker C (FXCWC)
I'll give the clutch basket a shake tomorrow, if I have the time to disassemble the primary cover.
Old 04-20-2017, 05:32 PM   #5 (permalink)
Nitram_b4's Avatar
Had to be something with the cable, you don't have a tapered shaft, besides most anything else would make some noise
2000 FXSTS
97"
KB Pistons
Ported heads
SE 203 Cams
Fueling Camplate and Pump
Fueling lifters
S&S Quickie Push rods
Red Shift Hyd Tensioners
HRS 42 Mikuni Carb
DTT Ignition
Nitram_b4 is offline   Reply With Quote Quick reply to this message
Old 04-20-2017, 09:36 PM   #6 (permalink)
Bonn85635's Avatar
It looks like the clutch ramp was stuck. Quite possibly since I put it back together.
I am assuming the ramp was partially engaged and I adjusted everything with it like that.
I went through it again this afternoon and re-adjusted everything. Now I have so much clutch I am thinking about renting some out.
Put her back together and will fill up the trans and primary tomorrow. It feels great though just running it through the motions a couple dozen times.
