Carburetor Jet Sizes for 2000 FLSTC? : V-Twin Forum: Harley Davidson Forums
Old 03-20-2017, 05:49 PM   #1 (permalink)
slowlane wants to know Dino or Syn?
I have a stock 88B with high flow AC and SE II pipes and get a little decal pop, otherwise it runs fine. I live and ride at approximately 5,000 feet. What carburetor jet sizes would be recommended?
I have not pulled the carb to see what's in there, but I suspect I have the OEM jets.
slowlane is offline   Reply With Quote Quick reply to this message
Old 03-20-2017, 07:46 PM   #2 (permalink)
HrleChk wants to know Dino or Syn?
Hang on , I'll ask hubby
Sent from my iPhone using Tapatalk
HrleChk is offline   Reply With Quote Quick reply to this message
Old 03-20-2017, 07:49 PM   #3 (permalink)
Nitram_b4's Avatar
first off has the cap been removed from the adjustment screw?
2000 FXSTS
97"
KB Pistons
Ported heads
SE 203 Cams
Fueling Camplate and Pump
Fueling lifters
S&S Quickie Push rods
Red Shift Hyd Tensioners
HRS 42 Mikuni Carb
DTT Ignition
Nitram_b4 is online now   Reply With Quote Quick reply to this message
Old 03-20-2017, 07:53 PM   #4 (permalink)
Nitram_b4's Avatar
Read this, it has you covered and saves me a lot of explaining. you don't have to do the mods except removing the plug from covering the idle adjustment screw
http://www.nightrider.com/biketech/hd_cv_mods.htm
2000 FXSTS
97"
KB Pistons
Ported heads
SE 203 Cams
Fueling lifters
HRS 42 Mikuni Carb
DTT Ignition
Old 03-20-2017, 08:15 PM   #5 (permalink)
He said he couldn't remember the number but he did say he went up ONE size on the slow jet, didn't bother the main jet and adjusted the air mixture screw out approx 1/4 to 1/3 of a turn.
Hope this helps. He did that on his when he got it ( 2005 TC 88 also ) and on my Softail Deluxe .( 06 .)
We have ridden from sea level to over 10,000 ft with no problems or further adjustments. Mine has 81,000 and his has 52,000 ( the rest were on the Electra Glide and it's fuel injected )
Old 03-20-2017, 09:35 PM   #6 (permalink)
tall terry is still riding a stock bike tall terry is still riding a stock bike
Definitely do as nitram says,,, screw the adjuster out 3.5-4 turns from lightly seated
Start with a 45 low jet, and a 190 high speed... a little big to compensate for altitude
Last edited by tall terry; 03-22-2017 at 12:13 PM. Reason: I hate this predictive text!!!!!
tall terry is offline   Reply With Quote Quick reply to this message
Old 03-22-2017, 10:38 AM   #7 (permalink)
Thanks all for your input. I checked and the cap is still in place over the idle mixture screw so I suspect I have the stock jets for my engine that being 160 main and 42 slow jet. I've read nightrider info a couple of times, in one place he recommends 10 over on the main which would be a 170 and next number higher on the slow which would be 45. In another place he recommends a 180 on the main. At my altitude I am guessing a 170 main would work best?
He also says to start at 2.5 turns out on the idle mixture screw and says under normal circumstances it should be between 2 and 3 turns out. Would the 3.5 to 4 turns Terry suggest then be if the standard jets remain and not replaced? If the jest are replaced as recommended then the additional 1/4-1/3 seems to be the rule of thumb. Correct?
Old 03-28-2017, 07:05 PM   #8 (permalink)
Nitram_b4's Avatar
First off if the cap is on there it more than likely is totally stock as you suspect and if so it is going to be lean to start with. personally, I would buy both an 180 and a 170 I would install the 180 first and a 45 slow is the smallest I would go, start there and adjust the screw as required
2000 FXSTS
97"
KB Pistons
Ported heads
SE 203 Cams
Fueling lifters
HRS 42 Mikuni Carb
DTT Ignition
