Brake pedal : V-Twin Forum: Harley Davidson Forums
Old 12-12-2012, 03:18 PM   #1 (permalink)
Gerald in Ga wants to know Dino or Syn?
Brake pedal
Howdy,
Does the softail use a brake pedal setup that does not have a master cylinder mounted in front of the pedal but has a smaller cylinder mounted back under the cam cover along side of the frame?
If so, what year would this be? Thanks.
Gerald in Ga is offline   Reply With Quote Quick reply to this message
Old 12-12-2012, 08:13 PM   #2 (permalink)
cernunos wants to know Dino or Syn?
Halloo. Gerald, my current ride, Angel, is an '86 Softail Custom and has the rear brake set-up you are talkin' about. Uses a remote reservoir at the front of the frame between the down-tubes. Hope that helps.
C.......
cernunos is offline   Reply With Quote Quick reply to this message
Old 12-13-2012, 12:12 PM   #3 (permalink)
Thanks cernunos.
