I just installed 95 bearings in a 07 200mm swing arm that i
am getting ready to put on my 95 bike. I am making my own wide tire setup. it doesn't look to be a big job. I will need to make a few
new spacers, i think. I won't know for sure till i get the original
swing arm off and try to put the 07 on. I have a Dusce wheel
and tire on now with a 1/2" offset chain drive setup.
1995 Bad Boy, Engine built to Stage 4 in 1998
Branch #5 heads, Matching Branch 11.8 Pistons
SE big bore intake manf W/42mm Mikuni
SE-57 cam, Crane 3/8 molly adj push rods
32" x 2.25 OD exh pipes Hyper charger air cleaner
Dyna 2000i adj ignition sys.
Blue streak Hi Opt coil W/10mm wires.
Dynoed at 93.5 HP
