Originally Posted by 1970pelle
I apologize so I yelled for one of my boys to help me out (LOL).He fixed up this photo. If you could give me so rough mesurments from Point A to B and C and a total. I have a fiberglass fender I'm playing with for a project. Not trying for a exact copy,but something close. Thanks Ken
OK - you didn't say if you wanted the numbers from the top or side, so I did it both ways...
(The fender itself is perfectly symmetrical, it's the same length from fork center-out in both directions - in fact, it appears as though you could unbolt it and flip it around and it wouldn't matter)
If I lay a tape measure along the top of the fender and follow the contour of the curve, the measurements are -about- 11 1/2" both ways - from the center of the forks to both fender tips - about 23" total, end-to-end.
If I just measure across the SIDE of the fender in a straight line, (holding the tape measure straight between the front tip and rear tip) the measurements are about 10 1/2" both ways from the center of the forks - about 21" total.
does that make sense?
hope this helps you out...
