Deuce rear brake peddle
I need to replace the right peg bracket , it got bent by the PO . I found one but when inspecting mine the brake peddle pivot shaft just came out of the bracket with the peddle. It looks to be a press fitted to the bracket ?
The bracket I'm getting doesn't have the shaft on it. Wished I'd looked at mine before I bid on it.
Can I just drill and tap it , use a bolt & washer or do I need to find one intact ?
