How To: adjust Softail rear shock preload - Page 2 : V-Twin Forum: Harley Davidson Forums
Old 08-10-2010, 08:24 PM   #16 (permalink)
ganno57 is on a distinguished road
The 2011 Manual is a little different. It states in turns out (counterclockwise) from minumum preload.
FLSTC, FLSTF, FLST
Less than 165 = 0
165 - 220 = 1
220 - 275 = 2
275 - 335 = 3
335 - 395 = 4
Greater than 395 = 5
FLSTFB, FLSTSB, FLSTN
Less than 185 = 0
185 - 235 = 1
235 - 285 = 2
285 - 340 = 3
Greater than 340 = 4
FXCWC
Less than 150 = 0
150 - 195 = 1
195 - 240 = 2
240 - 290 = 3
290 - 340 = 4
Greater than 340 = 5
Later,
Mike
2011 Street Glide 103
ganno57 is offline   Reply With Quote
Old 10-04-2010, 01:50 PM   #17 (permalink)
fatbillscustoms
FatBill is on a distinguished road
Petrock is the MFMAN!
signed: shock daddy
'10 Ultra Limited
V&H Dresser Duals (no cat)
V&H Monster Ovals
SERT - SE A/C
204 CAM
84 hp / 100.6 torque
'04 Fatboy
518 Chubby Wild 1's
Nacelle w/ passing lights
LePera Solo seat
V&H BS Staggered
SE A/C
remap
Progressive airtail
Z Pads (Lyndall Racing Brakes)
FatBill is offline   Reply With Quote
Old 10-05-2010, 12:08 AM   #18 (permalink)
The Anti-RUB
petrock's Avatar
signed: shock daddy
Thanks… Its based on your formula.
Sticky?
Vivid Black '06 FXSTBI
SE Stage-II 95"
My Two Front Teeph
Old 02-20-2011, 08:17 AM   #19 (permalink)
fatbillscustoms
Petrock....you are da man!
'10 Ultra Limited
V&H Monster Ovals
SERT - SE A/C
204 CAM
'04 Fatboy
518 Chubby Wild 1's
LePera Solo seat
V&H BS Staggered
SE A/C
remap
Progressive airtail
Old 02-24-2011, 04:41 PM   #20 (permalink)
swpwv's Avatar
swpwv is on a distinguished road
I have an '08 Fatboy that I've been thinking of changing the preload on for when my ol' lady rides with me, and this helps alot. My question is, does changing the preload significantly affect the handling or control of the bike?
swpwv is offline   Reply With Quote
Old 08-31-2011, 03:43 AM   #21 (permalink)
Lordlindsey is on a distinguished road
My GF and I are large.
I finally adjusted the shocks, about 4 turns on a 98 Fatboy.
Wow...what a difference. Ride is great now and have not noticed a change in handling.
Wish I would've done this a lot sooner.
Lordlindsey is offline   Reply With Quote
Old 08-31-2011, 04:33 PM   #22 (permalink)
Everrdi's Avatar
Everrdi is on a distinguished road
I agree
I just did this on my 04 FB and it made a HUGE difference in ride and handling (for the better!). I'm a big guy, 300+, and was considering going to a touring bike before I made this change but now that I adjusted the preload, my Fatty is securely under my butt.
The only thing is that it did raise the ride height the better part of an 1 to an 1 1/2 but I'll make that sacrifice for the better ride.
Everrdi is offline   Reply With Quote
Old 11-11-2011, 08:20 PM   #23 (permalink)
NUG
NUG's Avatar
NUG is on a distinguished road
Thank you for the detailed instruction. I'll give it a shot this weekend!
NUG is offline   Reply With Quote
Old 11-11-2011, 09:13 PM   #24 (permalink)
quickster47's Avatar
quickster47 is on a distinguished road
Really do appreciate this information. Saved me from buying some Legend air shocks this weekend.
Carl
Life is good and retired life is even better on a Harley.
quickster47 is offline   Reply With Quote
Old 11-15-2012, 02:41 PM   #25 (permalink)
sixparts is on a distinguished road
Originally Posted by petrock View Post
Softails's come from the factory with the lightest setting for the rear shocks (for <180lbs solo rider). However, they can handle well over 400lbs with no problems with a simple preload adjustment.
The service manual is a bit vague on how to set the preload. The procedure I use is fairly simple. Its based on the procedure from fatbillscustoms.com, but their website is gone now. It was fairly detained. I've made some tweaks to it for simplicity... Enjoy...
1) Jack the bike up so the rear tire is off the ground. The more clearance you have the easier it is. Don't forget to strap the bike down. You don't want it falling on you while your wrenching underneath it.
2) Loosen the jam nut all the way out. Its a 1-11/16" nut. If it doesn't want to loosen easily (which is often the case), soak it in some penetrating lube.
3) With a spanner wrench (HD p/n 94448-82B) turn the adjuster plate counter-clockwise (so the shock housing moves towards the front of the bike) until its up against the jam nut.
4) Then take a light colored paint pen, or a piece of duck tape, and mark the 6 o'clock position on the adjuster plate to use as a reference point when doing your adjustment. Don't worry if they're not in exactly the same position on both shocks. Thats normal.
Now your ready to adjust the shocks to your weight/load.
5) With the spanner wrench, turn the adjuster plate clockwise no more then 4 complete turns by counting how many times the mark from step 4 crosses the 6 o'clock position. 0 turns is the stiffest setting, and 4 turns is the softest setting.
6) While holding the adjuster plate in place with the spanner wrench, tighten the jam nut up against the adjuster plate by turning the nut clockwise.
6) Now repeat the exact same process on the other shock. The key is to adjust both shocks equally.
The general rule of thumb I use is:
4 turns for load <= 180 lbs
3 turns for 180lbs < load <= 235lbs
2 turns for 235lbs < load <= 300lbs
1 turn for 300lbs < load <= 375lbs
0 turns for 375 < load
Examples:
235lbs solo rider: 3 full turns
235lbs solo rider + 32lbs pack: 2.5 turns
235lbs rider + 150lbs passenger + 32lbs pack: 0.5 turns
I like a slightly stiffer ride when running solo (3 turns for my 235lbs fat booty), but run a softer ride when my girlies on the back (1 turn). Adjust your shock to taste by 1/4 turn increments till you get it dialed in for you and your riding style.
Note: you may be tempted to skip step 1 and not jack the bike up. Resist the urge. A stock ride height with the bike on its kick-stand, you may be able to use a crowsfoot or similar to get the jam nut loose, but you will have little to no room to use the spanner wrench. So take the time to do it right and jack the bike up. It only takes a minute (including strapping the bike down).
Enjoy...
Thanks for the info, it really helped, much more than the book. I made my own spanner wrench and finally got the ride i was looking for. if i can say one thing to anyone doing this,it would be to invest in a lift. i found one at a garage sale that needed a new jack, so my total investment was sixty dollars. best money i ever spent.
sixparts is offline   Reply With Quote
Old 11-15-2012, 06:03 PM   #26 (permalink)
cata5803's Avatar
Some good information.... Thanks...
2002 FLSTS, 2005 FLHT
Old 01-26-2013, 03:07 PM   #27 (permalink)
leeanders's Avatar
leeanders is on a distinguished road
Reading the 2013 Fatboy Harley 'Owners' manual on shock adjustment, it states: "Spring preload IS adjusted to the total load" It goes on to say the setting may be varied for personal comfort. By that "total load" setting at the factory. I assumed that meant it was preset for the stiffest ride - not the softest setting. Can anyone clarify? Thanks.
#15: 2013 Softail Fatboy
leeanders is offline   Reply With Quote
Old 02-08-2013, 01:44 AM   #28 (permalink)
Magik is on a distinguished road
Thanks for the info petrock! I may have to do some adjustments for some two-up riding.
Magik is offline   Reply With Quote
Old 02-08-2013, 07:38 AM   #29 (permalink)
Lakerat is on a distinguished road
Good info on preload adjustment, got a couple of friends who need these instructions. One of them can't even change his own battery without messing things up.
92 FXLR
97 Ultra (RIP)
98 95th Anniversary Ultra
PGR
Lakerat is offline   Reply With Quote
Old 03-15-2013, 04:30 PM   #30 (permalink)
hockeydawg12 is on a distinguished road
Very good info on the adjustment. I hadn't changed the shock adjustment on my Fat Boy in about 3 years. I couldn't get one loose to turn. After 2 hours of soaking the jam nut with PB Blaster and counter turning it alittle, I was eventually able to get it loose. Adjusted them right before a 1600 ride to NC and back. Made all the difference in the world riding two-up, fully loaded down.
hockeydawg12 is offline   Reply With Quote
