Clunking sound when shifting? : V-Twin Forum: Harley Davidson Forums
Old 02-11-2010, 09:07 PM   #1 (permalink)
Magneeto's Avatar
Magneeto wants to know Dino or Syn?
I'm used to the clunk when shifting into first but I recently went out for a spin and noticed some loud clunking while shifting through other gears. Its a five speed '04 fxstbi 95". Could it be that it was 38 degrees. I'll probably change all the fluids since it is probably time so what should I use for the tranny. Actually let me know what fluids I should use for all. Thanks.
2004 fxstbi
95"
S&S 570G cams
SE 10.25:1 pistons
BigBoyz Heads
CR: 10.15:1
Rinehart Cross Backs staggered
SE Diaphragm Clutch Spring
SEST
Magneeto is offline   Reply With Quote Quick reply to this message
Old 02-11-2010, 10:15 PM   #2 (permalink)
NorCal Dog's Avatar
NorCal Dog wants to know Dino or Syn?
ya the cold surely doesn't help keep em quiet any, i've got an '06 fatboy that does the same
just changed out the fluids today, put B&M Trick Shift ATF in the primary & Redline Shockproof Heavy in the gearbox & it made an immediate difference on how it shifted & sounded,, now it clicks into gear
NorCal Dog is offline   Reply With Quote Quick reply to this message
Old 02-12-2010, 12:31 AM   #3 (permalink)
Electric Head wants to know Dino or Syn?
I agree with NorCal Dog, I use the Synthetic B&M Trickshift ATF in the primary and Redline Heavy Shockproof in the gearbox and they work very well.
2006 FLSTFI
SE / K&N Intake
Andrews 26N 06 Dyna Conversion Cams
SE Billet Cam Plate
Khromewerks Tapered HP+ Slip-On Mufflers
Thundermax with Autotune
Electric Head is offline   Reply With Quote Quick reply to this message
Old 02-12-2010, 05:33 AM   #4 (permalink)
blipper
Scrubs's Avatar
Scrubs is reading this now saying WTF is this? Scrubs is reading this now saying WTF is this?
+1 on the Redline Heavy Shockproof. Makes a clunk into a snick.
I haven't tried B&M in anything other than a dirt bike...works well.
Scrubs
USAF MSgt (Ret.) nineteen & ninety - twenty ten
Scrubs is offline   Reply With Quote Quick reply to this message
Old 02-12-2010, 11:49 PM   #5 (permalink)
FireCap
ffatboy03 wants to know Dino or Syn?
Oh no! You got yourself a clunker. I wouldn't worry about it. I have an 03 Fatboy that clunks when I shift gears, especially from nuetral to first. Try some Rredline Shockproof Heavy. It quieted mine down.
ffatboy03 is offline   Reply With Quote Quick reply to this message
Old 02-13-2010, 06:29 PM   #6 (permalink)
Ironbutt
MilesToGo's Avatar
Interesting... I run the Heavy Shockproof in all my trannies. In my experience, when the tranny fluid is cold and thick there is LESS clunk. It's when it gets heated up and thinner i notice more clunk.
Current bikes in the stable:
2009 Street Glide
2003 Heritage Softail Classic
Old 02-13-2010, 09:54 PM   #7 (permalink)
FireCap
Actually mine is the same with the Redline. Some harley trannys just clunk more than others. Mine is definately a clunker.
Old 02-14-2010, 05:15 PM   #8 (permalink)
HogBag wants to know Dino or Syn?
I would check clutch adjustment inside derby cover first. How many mile on your bike the plates might need replacement.
HogBag is offline   Reply With Quote Quick reply to this message
Old 02-18-2010, 04:58 AM   #9 (permalink)
I agree with Hogbag, transmission clunking is more likely caused from clutch not disengaging properly than from the gearbox itself. Clutch adjustment, primary oil level or condition would be the likely causes - just like the cold-into-first clunk.
2006 FLSTFI
SE / K&N Intake
SE Billet Cam Plate
Old 02-24-2010, 12:39 PM   #10 (permalink)
Magneeto's Avatar
I went out for a ride the other day. Let the bike warm up for 10minutes and I didn't have the clunking problem. Well, first gear but that is always the case. I think it was the cold weather.
2004 fxstbi
95"
S&S 570G cams
SE 10.25:1 pistons
BigBoyz Heads
CR: 10.15:1
SEST
Old 02-24-2010, 12:57 PM   #11 (permalink)
jonny oz's Avatar
jonny oz wants to know Dino or Syn?
http://www.harleyhog.co.uk/hippovpc.htm
check this out. came across it a while ago, ordered one yesterday. apparently does away with the clunks completely, and adds clutch capacity to boot! cant' wait.
they responded to my emails quickly and were quite helpful.
2006 Night Train
95"
SE Cast Flat Tops
Big Boyz street heads
V&H Hi Lo Straightshots
Ness Big Sucker
PC3
07 camplate and oil pump
Andrews 26N conversion cams
Hippo VPC
Progressive fork springs
2003 Sportster 1200S based rigid chop
jonny oz is offline   Reply With Quote Quick reply to this message
Old 02-24-2010, 01:29 PM   #12 (permalink)
Magneeto's Avatar
Therer is a recent thread on it. Search: should I upgrade my clutch spring
2004 fxstbi
95"
S&S 570G cams
SE 10.25:1 pistons
BigBoyz Heads
CR: 10.15:1
SEST
Old 02-24-2010, 03:37 PM   #13 (permalink)
Pop's Cycle wants to know Dino or Syn?
I agree with less clunk when warm - mine clunks initially when it's cold out. Also, using tranny lube instead of engine oil makes a big difference.
Pop's Cycle is offline   Reply With Quote Quick reply to this message
Old 02-24-2010, 04:57 PM   #14 (permalink)
Ironbutt
MilesToGo's Avatar
From what i've read, the VPC is great for moded engines requiring a stronger clutch while keeping the lever effort down at lower rpms, but i've never heard of it getting rid of the clunk. Pretty pricey item just to reduce the noise a little. Let us know how you like it.
2009 Street Glide
