Bub EnterprisesMotorcycle.comRRcycles.comPro PadSportbikeTrackGearMBO Enterprises
JardineProducts.com
Dan Vance Racing
Old 10-23-2009, 03:15 PM   #1 (permalink)
fxst2000 is on a distinguished road
Deuce rear caliper question
Anyone know fro sure if the rear brake caliper from a deuce is the same caliper that came in the wide tire kit for 00-02 softails? Want to fatten up the back with a 150 tire, but want to look into all the different ways of doing it.
fxst2000 is offline   Reply With Quote
Old 10-23-2009, 03:44 PM   #2 (permalink)
blah, blah, blah....
Shaw_2112 is on a distinguished road
Not certain the wide tire kit came with a new caliper?? But yeah the deuce caliper will work if you buy the new spacers to center the wheel properly. Don't forget to reverse the fender strut bolts while you're at it..
It may be that your only purpose in life was to serve as a bad example to others.....get over it....
Shaw_2112 is offline   Reply With Quote
Old 10-23-2009, 04:26 PM   #3 (permalink)
It's never fast enough...
DLRVelocity1's Avatar
DLRVelocity1 is on a distinguished road
While you're at it, why not go to a 180mm tire? It'll fit if you do like Shaw says in his post with the spacers and centering the wheel with the centerline of the fender / backbone. I've done several Deuces and a few Softails up to 200mm using Avon tires.
I'm less afraid of dieing, than I am of not having lived...
'02 FX"C"ST
95 Screamin' ci.
SBC Heads
Andrew's 37G's 2deg. Adv.
Crane Easy Adjust Rods / Hydro-solids
Bob Wood Performance 415 Carb
SE 2/1 Pro Pipe "V&H" Custom Billet End Cap
Daytona Twin Tec Ignition
Baker 3.48:1 Gearing
SE / Barnett CF Clutch
Avon 200 x 55 x 18 Rear Tire
Weld Recluse Wheels, Rotors and Pulley
Ness / Cycle Visions Custom 5" Fwd Controls
V1 Engineered 200mm Tire Retrofit
DLRVelocity1 is offline   Reply With Quote
Old 10-27-2009, 03:40 PM   #4 (permalink)
180 is too big, the biggest a 2000 will take is 160. I've maxed mine out...
