Leslie Kay'sDiamond Bar ChoppersJekillandHyde.euCycleGear.comCustom DynamicsAdvanstarMotorcycleShowsAmerican Side Road CycleMotorcycle-Communication
JardineProducts.com
Old 10-03-2009, 09:21 PM   #1 (permalink)
phillipsgtx's Avatar
phillipsgtx is on a distinguished road
Lowering kit help - bottoms out
I recently had a Heartland E-Z Rocker kit installed on my 08 FXCWC with a 2" lowering kit install on the rear shocks. With the extenders adjusted to the minimum amout of lowering the swing arm bumper bottoms out. Any insight from someone who has installed a progressing lowering kit? The rest of the conversion went great.
phillipsgtx is offline   Reply With Quote
Old 10-03-2009, 10:23 PM   #2 (permalink)
The Anti-RUB
petrock's Avatar
Is the rear shock's preload adjustment set to your weight? If not, you'll bottom out like crazy with a 2" drop. If you do, you might want to increase the preload a bit to compensate for the 2" drop. Good luck...
Vivid Black '06 FXSTBI
SE Stage-II 95"
My Two Front Teeph
Old 10-03-2009, 10:33 PM   #3 (permalink)
I would like to do it now so I could enjoy riding tomorrow. A crash course in preload adjustment would be great....Thanks
Old 10-04-2009, 10:59 AM   #4 (permalink)
rcsoftail is on a distinguished road
Found some instructions. You will need the spanner wrench.
Adjustment range is approximately 4 full rotations.
1.) Loosen pre-load adjustment lock nut. (re. to fig. 1)
2.) Using a special tool such as our ZPN 750803 Softail
shock pre-load tool, turn adjusting plate clockwise to
stiffen pre-load & counter-clockwise to loosen pre-load.
(re. to fig. 2)
3.) Lock down pre-load adjusting nut using a medium
strength thread locker such as Loctite “Blue” or Permatex
“Blue” when pre-load has been set
Here's a link http://zodiac-nl.hu/instructions/243067.pdf
rcsoftail is offline   Reply With Quote
Old 10-04-2009, 11:00 AM   #5 (permalink)
The Anti-RUB
petrock's Avatar
Check out www.fatbillscustoms.com page on adjusting shock pre-load. Its the guide I use to adjust my shocks. Only step they don't list is putting the bike up on a lift and strapping it down securely with tie down straps so you have room to work and not have to worry about the bike wiggling off the lift as you mess with the adjustment.
When ever I adjust my shocks I use zero turns as the baseline. I turn the spanner thingy until there are zero threads and then adjust it to the weight I need. For my 235lbs fat bootie I use three full rotations (three threads). When I've got the girlie on a long ride, I use one full turn. When I've got the girlie and a loaded T-Bag strapped on the backrest/luggage rack, I use zero to .5 turns depending on the weight of the loaded T-Bag. Takes about 20 minutes from start to finish (now that I've done it a bunch of times).
I'd recommend adjusting it to fit your weight. Ride it around and see if it bottoms out or not. If it does, adjust it stiffer (1/4 turn) and do another test ride. Repeat until it stops bottoming out. Good luck...
SE Stage-II 95"
My Two Front Teeph
Old 10-04-2009, 04:51 PM   #6 (permalink)
Sure do appreciate the input. I'm all over it first thing in the morning. Thanks again for the help....
Old 10-17-2009, 06:55 PM   #7 (permalink)
After several rounds of adjusting, the final solution was to replace the bump stop with a 07 softail standard piece. The stock Rocker bump stop was an inch longer to protect the swing arm mounted fender. The change out took all of 15 minutes. With the Heartland kit installed it was no longer needed due to the strut mounted fender. Now I have the shocks set in the center adjustment with the bike lower an inch and a half and it rides and looks great. Thanks to all who responded, I am now fully versed in the full on EZ Rocker Heartland conversion as well at the softail lowering investigation that came with it.......
08 Rocker
Heartland EZ Rocker Kit
Heartland front fender
Frenched Plate and Tail light
Danny Gray seat
Rush pipes
Chrome swingarm
Custom paint
Some see life as Black and White. I view life as Crimson Sunglo and Chrome!
Old 11-19-2009, 07:16 AM   #8 (permalink)
fatbillscustoms
FatBill is on a distinguished road
Before you put it on a lift and secure with straps...make sure you eat food for energy and breath air so you don't pass out and ....
'04 Fatboy
518 Chubby Wild 1's
SS Braided Cables
Chrome front end
Chrome rear end
Nacelle w/ passing lights
LePera Solo seat
Stage 1 EFI
V&H BS Staggered
PCIIIusb
Progressive airtail
Z Pads (Lyndall Racing Brakes)
Black/Blue Devil Tails
FatBill is offline   Reply With Quote
