Powerstar Sparkplugs
ProCharger.comMotorcycle.com Classifieds!BikeBanditCycleGear.comOriginal Bike SpiritsSportbikeTrackGearDiamond Bar Choppers
Leslie Kay's
Old 09-29-2009, 08:58 PM   #1 (permalink)
cgall66's Avatar
cgall66 is on a distinguished road
Brake Caliper Upgrade Suggestions Please!
Ok heres the deal, I got a 1995 FXSTC with stock brakes. I really want to upgrade te caliper from single piston to multi piston calipers, but I want them to work with the existing master ccylinders. I mainly want this upgrade for safety and peace of mind, but would really appreciate some input from the V-Twin forum community.
Thanks and be safe out there
cgall66
cgall66 is offline   Reply With Quote
Old 09-29-2009, 09:16 PM   #2 (permalink)
Performance Machine and Jay Brake would be 2 good sites to check out. I can say from personal
experience the P.M. brakes work very well. Have heard good reviews on JB stuff also.
_______________
04 softail standard
Baisley-Axtell 117 - Baisley pro street heads - Baisley hybrid injection
Bob Wood TW-8 - Darkhorse crank - P.M. Hydraulic clutch
P.M. Villain wheels-rotors
Builder - hdryder
Phat117 is offline   Reply With Quote
Old 09-29-2009, 09:29 PM   #3 (permalink)
cgall66's Avatar
Thanks Phatt, by the way thats one bad ass softail, what lowering springs are you running in the front end on that beast.
Old 09-29-2009, 10:25 PM   #4 (permalink)
Thanks! The front end hasn't been lowered. Stock front end with chrome lowers and Hawg Halters
triple trees that have some added rake.
Hawg Halters would also be another option for your brakes.
_______________
04 softail standard
Builder - hdryder
Old 09-30-2009, 08:08 AM   #5 (permalink)
Doof Toll Pimp
ktwillys's Avatar
ktwillys is on a distinguished road
the least expensive way and best for funtion is to upgrade to the HD stock 2000 and later system..
it is a 4 piston system..
all you need to do is to replace your lower forks with the later lower forks.. can be found fairly cheap..
and then you can use the HD stock calipers and your wheel should accept the later stock rotor..
depending on whether you are using dual or single disc that will change your cost a little bit.
as for the master cylinder you can use your existing one provided the brake line has the correct banjo fitting for the calipers.
you also have to make sure that you are using the correct fluid.
the later HD brake system uses DOT 5 and it doesnt play well with the other type fluids..
worst case is that you have rebuild the calipers to clean out all the existing fluid and then run what you are currently using..
this is really a simple and cost effective way to upgrade the brakes on your bike...
I have done this several times... it really is easy..
To be old and wise,
Here's to old and stupid....
Orthopedic Motto
DC.....
04 FLTRI
SE Welded/Balanced Flywheel
103 Cubes
CP Hi-Comp Pistons
Andrews 54G Gear Drive Cams
S&S Hi-Lift Valve Springs
Timken Conversion
Baisley SuperSTock Heads
V&H True Dual Headers
Bassani Slip-on Mufflers
Thunder Max Ignition System
Feuling Oil Pump
Custom Feuling Cam Plate
ktwillys is offline   Reply With Quote
Old 09-30-2009, 09:34 AM   #6 (permalink)
VRSCR's Avatar
VRSCR is on a distinguished road
I agree with KTWillys reply. Also with a lower leg change, you can go with a Brembo caliper or dual if you use the legs from a FLHT. The Brembo style rotors bolt right up as well!
Home of the 9 second street ridden 1130cc VRod
NOTICE: Info I post may be correct and relevant to threads posted in. Yet I may have learned this info else were and am just sharing it in a public forum for other members benefit. I am not responsible for any tantrums or fits you may have because it was read else were on the world wide web!
VRSCR is offline   Reply With Quote
Old 09-30-2009, 11:16 AM   #7 (permalink)
mark_bert is on a distinguished road
Another option is to get a bracket that will allow you to use a sportbike caliper. Check out http://www.fabkevin.com/front_brake.htm. It runs about $225 for the bracket and caliper. You can probably get the bracket alone and look for a caliper on ebay (tons of them there). On a bike I used to have, I did the same idea with a caliper I got on ebay for about $10. Made the bracket myself out of some 1/4" plate that I cut with a jigsaw.
I turned 43 on my last birthday
DFFD
mark_bert is offline   Reply With Quote
Old 10-02-2009, 06:14 AM   #8 (permalink)
VRSCR's Avatar
Keep usposted as to what you do and how you liked it.
Old 10-06-2009, 06:27 PM   #9 (permalink)
rcsoftail is on a distinguished road
I went with a P.M. on my 95 flstc. Easy bolt on part, looks great and has increased the braking ability, but are not cheap. They used to sell a less expensive brushed finish version that matched the factory fork legs. The single piston factory caliper was a safety hazard and almost got me in several accidents due to the severe brake fade. I figured my life was worth the $300+ for the new caliper. Maybe I should have just gone slower and stayed in the slow lane.....
rcsoftail is offline   Reply With Quote
Old 10-06-2009, 06:30 PM   #10 (permalink)
Does the 2000 later systems use the same diameter brake rotor as the earlier models? Thanks
Old 10-07-2009, 10:44 AM   #11 (permalink)
jonny oz's Avatar
jonny oz is on a distinguished road
does anybody know anything about sportbike calipers??
I know most (all?) have dual fronts...i'm considering buying a single front sportbike caliper to replace my stock 06 night train front caliper...stopping power on the front is a little light for my liking.
i am under the assumption that this would increase stopping power significantly, but would like some input before moving forward with anything. i found a caliper on ebay from an r1 that is black that i don't think would take much work to make fit.
input appreciated.
thanks.
2006 Night Train
V&H Hi Lo Straightshots, black heat wrapped
Ness Big Sucker
PC3
homemade paint (flat/gloss flame job)
*waiting for tools*
07 style camplate, pump, tensioners etc.
Andrews 26N conversion cams
Hippo VPC
SE quick install adjustables
can't wait!
jonny oz is offline   Reply With Quote
Old 10-08-2009, 03:39 AM   #12 (permalink)
hksigman's Avatar
hksigman is on a distinguished road
input appreciated.
thanks.
Im running a PM 6 on my 06 nitetrain and love it. Like someone said they are pricey ($450-500) but it looks bitchin especially with the Marzocchi inverted forks
2007 Roadglide Orange
Yaffe Monkeybars, Bassani sweeper exhaust
2006 Softail Deluxe Gloss Black
1 1/2 inch broomstick drags, LaPera seat, Samson fishtails, flame-skull rims
2006 Pearl Black Night Train
Heartland rear fender, 18" fat 50 front rim, Yaffe X-Pipes, 1 1/2" Carlini "lowdown" bars
2005 Roadking Classic Silver(back on the road)
Carlini 1 1/2 inch Clean Sweep Bars, Rhinehart True Duals, 18" PM Contrast Torque Rims
hksigman is offline   Reply With Quote
Old 10-08-2009, 04:31 AM   #13 (permalink)
Cop_Stanger's Avatar
Cop_Stanger is on a distinguished road
Pics????
Tom S.
2005 FXSTB
My photos:
http://public.fotki.com/ascmclaren/
"The trouble with the world is that the stupid are cocksure and the intelligent are full of doubt" --Bertrand Russell
Cop_Stanger is offline   Reply With Quote
Old 10-08-2009, 06:13 AM   #14 (permalink)
Lost Hippie is on a distinguished road
I used the caliper kit from Ultima on the stock master cylinders... Worked all year... They are not perfect finish-wise, but for $250 for the pair, I couldn't complain. They have the new style looks, and mount on 99 and earlier softies...
Lost Hippie...
Following the adventures of Hogg Ryder and Ol' Poop....
97 FXSTC, .005 over (hey, that's +.25 cu. in.!!!)
V-Thunder 3040 cam,
Hooker Troublemaker pipes,
+2" forks, +5 degree trees
80 spoke front & rear wheels
Metzler 880 front & rear
Ultima retro fit calipers
Lost Hippie is offline   Reply With Quote
