CycleGear.comMotorcycle.comDiamond Bar ChoppersAmerican Side Road CycleStainless Ride Specialty AccessoriesFuel Moto
Old 09-27-2009, 06:32 PM   #1 (permalink)
arthur6 is on a distinguished road
Changing pulleys (sprokets).... Want to gear up
Guys, ....03 Softtail Standard....
How many teeth are on the rear pulley of Softtail? 70 teeth ??
I’m looking to gear mine up (slower revs at 75mph)
The front is 32 teeth, I can get a 34t but will be pretty hard to swap.
So… I THINK the rear is 70 teeth, I see some 66t pulleys on-line used, seems that would be easier to change.
Will these swap?
THANKS
arthur6 is offline   Reply With Quote
Old 09-28-2009, 10:54 AM   #2 (permalink)
have you considered a larger motor sprocket?
Old 09-28-2009, 11:27 AM   #3 (permalink)
Larger motor pulley... Yes, I looked into it.
A motor pulley is about $125... hard to change.
A rear pully is about $70.... easy to change.
This the question...
Will a pulley form a Dresser/Bagger (66t) fit my 03 Softtail??
My Softtail has a 70 tooth pulley.
Old 09-29-2009, 10:07 AM   #4 (permalink)
the belt is harder to change than the motor sprocket/primary chain. also, if you change motor sprocket, your speedo stays accurate.
Old 09-29-2009, 11:08 AM   #5 (permalink)
Oh...
I was talking the TRANS Pulley
I see you guys are talking the ENGINE sprocket
Have not considered that
Is it hard to change?
I'm guessing I'd go bigger (more teeth)?
How many more? 1? 2?
What different teeth can I choose from?
Anyone here changed one?
Old 09-30-2009, 10:24 AM   #6 (permalink)
question: do you have the power required to pull taller gearing? can you deal with the additional heat? will you be ok with the drop in economy? you can potentially damage the drive train also.
there is a reason most go the other way on gearing.
3000 rpm at 70 mph is revving too fast for you? its your bike, just want to make sure you know the issues before spending time and money to drop 300-400 rpm and cause problems.
yes, you would go larger on sprocket.
