Motorcycle-CommunicationCustom DynamicsSportbikeTrackGearAdvanstarMotorcycleShowsDiamond Bar Choppers
RRcycles.comFuel MotoBub EnterprisesProCharger.com
Old 09-24-2009, 05:20 PM   #1 (permalink)
blewcrab is on a distinguished road
twin cam 88 cam chain tensioner
my 2003 twin cam has 21,000 miles ...I am told that the cam chain tensioners need to be replaced at 20K ....anyone with any feedback on this?
blewcrab is offline   Reply With Quote
Old 09-24-2009, 05:26 PM   #2 (permalink)
squale147's Avatar
squale147 is on a distinguished road
iv seen them last till 60k and go as early as 15k.. not a bad idea to check them
motocross#147 drag racing#4933
squale147 is offline   Reply With Quote
Old 09-24-2009, 05:31 PM   #3 (permalink)
Nahanhoku is on a distinguished road
68000 on the first set of tensioners. I only changed them because I was upgrading cams.
Here is one of many threads on the subject.
http://www.v-twinforum.com/forums/to...tensioner.html
2000 FLHR
Stage 1 w/ SE-203
Nahanhoku is offline   Reply With Quote
Old 09-24-2009, 08:52 PM   #4 (permalink)
Sales Weasel
miker84's Avatar
miker84 is on a distinguished road
I looked at mine at 20k and they looked normal. Mine were about half worn at 30k. Helped a friend replace his tensioners a couple of weeks ago because his had worn into the metal on the arms at 30k miles. He noticed a ticking that hadn't been there before. It probably depends on how many hours the engine has run and the type of maintenance done rather than the miles.
2003 FXSTi
98hp, 105TQ
95" Bored Cylinders
BigBoyz Heads (Street Port, CC'd, Milled)
SE Flat-Tops
Andrews 37G Cams
Zippers SE Air Cleaner
PCIII
Rivera Pro Clutch (Silver)
LeatherPros Bags
Mustang Touring Seat
HD Quick Attach Windshield
FatBoy Rear Fender
M880 160 Rear, 120 Front
Thunderstar Wheels
miker84 is offline   Reply With Quote
Old 09-24-2009, 10:07 PM   #5 (permalink)
shop14 is on a distinguished road
just checked mine at 28k, all good. another 10k before i check them again.
shop14 is offline   Reply With Quote
Old 09-24-2009, 11:43 PM   #6 (permalink)
mooooving out!
route66paul's Avatar
I would check them at least, they have been known to go even before 20k.
43%er
Bi-polar and loving it!!
Bi-polar and hating it!!
95" w/ KB pistons (flattops)
HQ575 cams
Atwood's Road Warrior Heads
.030 head gasket
SuperTrapp Supermeg 2in1
"43" points cover
TRW rear mount
obligatory Baisley Spring
Just sayin..........
Old 10-01-2009, 11:12 AM   #7 (permalink)
chromejunkie's Avatar
chromejunkie is on a distinguished road
Mine had very little wear when I changed cams at 38K. Still, it wouldn't hurt anything if you popped the cam cover off and took a look at them.
2006 Heritage Classic
Candy Blue w/metalflake ghost flames
Chrome 6 spoke slotted wheels
chromejunkie is offline   Reply With Quote
Old 10-01-2009, 11:21 AM   #8 (permalink)
niget2002 is on a distinguished road
Crap... I knew I forgot something.
I just did the 30k on my bike. I meant to check these. Guess I know what I'll be doing tomorrow.
!43
Current Build
'06 FXSTBi
Tc 88B
V&H Big Radius
SE A/C
DTT tcfi IID
niget2002 is offline   Reply With Quote
Old 10-01-2009, 11:47 AM   #9 (permalink)
Big-G's Avatar
Big-G is on a distinguished road
Will the engine tick or knock when they go bad? Or what is a sign without actually looking at them?
Gerald
2004 Heritage Softail
Big-G is offline   Reply With Quote
Old 10-01-2009, 04:18 PM   #10 (permalink)
mooooving out!
When they "go bad' they frag and send plastic pieces all through your engine, and maybe some metal also. depending how bad they go, you could only be looking at replacing the oil pump, but many times this can cause a complete overhaul and many parts need to be replaced. At that point, it is time to think about going to a 117, 120, or a 124". $7000+ range
43%er
HQ575 cams
.030 head gasket
"43" points cover
TRW rear mount
Old 10-01-2009, 05:20 PM   #11 (permalink)
its a pain in the ass to keep checking them , always having to worry about them... they break no warning and can blow your motor. just save a lil and gear the cams all worries gone! it'll help your motor breathe better as well as perform better.
Old 11-19-2009, 10:40 AM   #12 (permalink)
Seawolf is on a distinguished road
Cam Chain Tensioners @ 33K
My 2006 FLSTC has been carefully maintained in accordance with the H-D recommended service schedule that no where mentions the cam chain tensioner shoes. After reading in this forum, I asked the dealership about the cam chain issues. They recommended having them checked at 30K. It is never verbally or printed by H-D as a maintenance issue unless one directly inquires about it. As a result, I inspected mine. The inside rear was nearly gone and the front was out of tolerance. I replaced the spring tensioners with hydraulic tensioners ( expensive, but less so than a geared system for now). In the future, I will inspect the shoes and chain every 25K.
Experience is a hard teacher because she gives the test first, the lesson afterwards.
Seawolf is offline   Reply With Quote
Old 11-19-2009, 11:50 AM   #13 (permalink)
Doof! There it is.....
'05Train's Avatar
'05Train is on a distinguished road
Switched to gears at 19,000 miles, shoes looked decent. I'd check 'em every 10,000 miles or so if I still had them.
'05 Vivid Black Night Train
Lots o' black
103 by Dave at JD's
116.70/116.01 SAE
'05Train is offline   Reply With Quote
Old 11-19-2009, 11:56 AM   #14 (permalink)
Skywarrior is on a distinguished road
Inspected cam chain tensioners at 38k, not much wear, decided to change them this winter and was surprised to see how much wear I had now with 56k. Upgrading to S&S gear drive with Black Widow 540 cam also going from 88" to 95".
Skywarrior is offline   Reply With Quote
Old 11-19-2009, 02:30 PM   #15 (permalink)
46u
46u is on a distinguished road
Checked mine at 50,000 miles and the pads where GONE metal on metal. Had to replace everything but the cam plate in the came case. I now have 78,000 going to replace them with the kit that changes them over to the later style hydraulic ones. It all so comes with the up dated oil pump that helps with the scavenger problems. All so since Harley has doubled their price on the adjusters and cam chains. The Kit all so comes with the new style primary chain set up and you still use your cam bearing set up not bushings like the later models. If you check around you can get the whole kit for around $350 to $380 which the kit retails for $429. One other thing comes with a billet cam plate.
46u is offline   Reply With Quote
