SportbikeTrackGear
Old 09-21-2009, 10:13 AM   #1 (permalink)
Koop08's Avatar
Koop08 is on a distinguished road
Rear oxygen sensor help needed
My son has a 09 Night Train and we are replacing the stock exhaust with V&H Short shots. Everything was going well, until we started to put in the rear 02 sensor into the new pipe. It only goes in maybe 2 turns then stops. It looks like the threads on the new rear pipe are not drilled right. I don't want to force the sensor in and mess it up and we're leaving in a few days for a trip so sending the pipe back to Vance and Hines won't work. Any suggestions? Would a muffler shop be able to tap it out? The stealer isn't open until tomorrow. Thanks in advance.
Koop08 is offline   Reply With Quote
Old 09-21-2009, 10:17 AM   #2 (permalink)
Audentes Fortuna Juvat
nightrob's Avatar
Tap it!! If you cant find a tap big enough, pull the pipe and take it to a machine shop or maybe a muffler shop. Or worse case scenario have a muffler shop cut the bung out of the stock pipe and weld it into the new one.
2007 FXSTB
Friedrich Nietzsche
Old 09-21-2009, 10:36 AM   #3 (permalink)
2005 Road King Classic
bbrowncods's Avatar
bbrowncods is on a distinguished road
There is an O2 sensor tap. I got mine from an ACE Hardware store. I am at work and don't have the thread/size, but you can look it up. A good hardware store will have one. Shame on V&H for not chasing the threads with a tap after welding. That is rule number one.
05 Road King Classic - Sierra red pearl/Bassani Power Curve and Megaphones w/torque baffles/98" RevPerf BB/37g cam's/Stock 99B lifters/TTS/Stage 2 CNC'd heads by R&R(GMR) 9.7 CR/50mm Gerolamy Dual Throttle and filter/500cc injectors/Super Premium Oil Cooler/SE Clutch spring w/Easy-pull ramp and a bunch of this and that!
bbrowncods is offline   Reply With Quote
Old 09-21-2009, 12:20 PM   #4 (permalink)
strokerjlk's Avatar
18 mm thread not sure of the pitch. 2.5 I think.
it is the coursest thread of the 18 mm.
07 ULTRA
S&S 106 CI
Big Boyz heads
D&D Fatcat
Green A/C
HQ 575
HQ Black opps lifters
SERT/ upgraded to TTS
GARMIN 2610
3 GAL. AUX FUEL CELL
IBA# 31913
BBG
1566 MI 23 HR'S
Thomas Jefferson
Old 09-21-2009, 01:52 PM   #5 (permalink)
Koop08's Avatar
Thanks guys for all the info. I just got off the phone with a muffler shop and he said no problem tapping it out. It must be a common problem since they make a special tool for it. I am disappointed in Vance and Hines a little for sending out a part that wasn't properly drilled, but then I guess that goes under the heading..."s#*t happens".
Should be on the road tomorrow.
Old 09-21-2009, 06:44 PM   #6 (permalink)
Eleft36's Avatar
Eleft36 is on a distinguished road
18 mm spark plug tap, same thread the bungs are.
Auto parts store
Al
Back to stock mufflers K&N A/C Stock Heads Andrews 26 Cams SE103" Kit Mustang Wide Touring Seat Stock Bars H.D. Oil Cooler 1994 Fat Boy Bags H-D Windshield Thunder Max A/T
SE Compensator Kit
Eleft36 is offline   Reply With Quote
Old 09-21-2009, 08:53 PM   #7 (permalink)
Axe Man
BVBOB's Avatar
18 by 1.5 mm tap, pretty common to see them messed up.
2007 Ultra
Woods 7H cams
Heads ported by BigBoyz
D&D Fatcat, SE/AC
1982 FXRS
Scratched paint
Rotten tires
Bad brakes
Sticky clutch
Still runs like a champ!!
