09-20-2009, 12:19 PM
Loose Kickstand Spring
This is my second spring on my 2003 Deuce. Works for about 2 days and now the kickstand hangs loosely below bike an inch or 2, occasionally dragging on left turns.
What's the deal here? Are there better aftermarket springs? Springless stand? Thanks
2003 Deuce FXSTDi 95"
SE Performance Heads (cleaned Up)
Thundermax EFI w/AT
VH Big Radius 2-1
Andrews 54N cam
SE Heavy Breather
09-21-2009, 09:02 AM
Whats the deal with your kickstand? It seems like something is worn out letting it hang down loosely. It doesn't sound like a spring problem, but a mount problem.
Mike
09-21-2009, 09:28 AM
I'm on my second replacement too on my ultra but i know its my mini curb in backyard that if i take too fast willl hit spring and stretch it out
09-21-2009, 09:42 PM
It sounds like the attachment hole on the kickstand arm is worn or slotted and lets the arm dangle. Check both attachment holes for wear.
Regards; Lex
1998 DYNA WideGlide
2003 RoadKing Classic
2005 Heritage Softail Classic
09-21-2009, 11:32 PM
I say the Jiffy Stand catch is bad.I see it all the time....I work at a HD dealer here in Iowa.Older softail jiffystands=bad catch and spring.....
2006 XL1200C with S/E Heads,551 Cams,Perfect Fit Pushrods,Cylinder Studs,42MM Mukuni,Manifold,Clutch,Igintion Module,Plugs,Wires,Arlen Ness Big Sucker,Vance and Hines Shortshots Staggered and the rest of the bike chromed out!
2007 FXSTC with S/E 110 Heads,103 Cylinders,Pistons,Adjustable Pushrods,58MM Throttle Body,Manifold,Heavy Breather,Plugs,Wires,S&S 585C Cams,Zippers ThunderMax,Vance and Hines Big Shots Staggered and the rest of the bike chromed out!
09-22-2009, 06:57 PM
That's one thing I hadn't thought of yet. Any chance you know the part number for a new catch? Thanks for everybody's replies.
Thundermax EFI w/AT
VH Big Radius 2-1
Andrews 54N cam
SE Heavy Breather
09-23-2009, 11:49 PM
It should be 50015-74A but check with your local dealer.
03-12-2010, 10:59 PM
Jiffy Update
Just an update to my spring problem. Happened to be in a Dealership today. I explained that this is my 2nd spring to the service manager and The stand is still loose.
I asked if there was a solution assuming that I am not the only one that has seen this. He suggested " replacing the spring". Where do they find these idiots?
What has anybody else done?
Thundermax EFI w/AT
VH Big Radius 2-1
Andrews 54N cam
SE Heavy Breather
