07 chain drive conversion : V-Twin Forum: Harley Davidson Forums
Old 01-21-2009, 07:56 PM   #1 (permalink)
Daz
Daz's Avatar
Daz wants to know Dino or Syn?
Gday fellas, I am in Australia and looking for a US manufactured rear chain drive conversion kit for an 07 softy, can anyone help me out?
cheers Daz
Daz is offline   Reply With Quote Quick reply to this message
Old 01-21-2009, 08:11 PM   #2 (permalink)
Peacekeeper's Avatar
Location: A Little South of Sanity...A Little North of Reality...
Peacekeeper wants to know Dino or Syn?
Originally Posted by Daz View Post
Gday fellas, I am in Australia and looking for a US manufactured chain drive conversion kit for an 07 softy, can anyone help me out?
cheers Daz
I think Zipperers (spell check) makes some.
2004 Electra Glide Classic FLHTCI
Lava Red and Black, Its name is "Ole Red"
Never Forget 10/23/1983
Peacekeeper is offline   Reply With Quote Quick reply to this message
Old 01-21-2009, 09:52 PM   #3 (permalink)
route66paul's Avatar
You have the better one, there is really no need for gears - and 07s and later tend to have too much runout for geardrive cams. Those chains are ok.
43%er
Bi-polar and loving it!!
Bi-polar and hating it!!
95" w/ KB pistons (flattops)
HQ575 cams
Atwood's Road Warrior Heads
HPI bored throttle body
.030 head gasket
SuperTrapp Supermeg 2in1
"43" points cover
TRW rear mount
obligatory Baisley Spring
Just sayin..........
Old 01-21-2009, 10:48 PM   #4 (permalink)
Electric Head wants to know Dino or Syn?
I'm fairly sure he's after a chain final drive conversion.
2006 FLSTFI
SE / K&N Intake
Andrews 26N 06 Dyna Conversion Cams
SE Billet Cam Plate
Khromewerks Tapered HP+ Slip-On Mufflers
Thundermax with Autotune
Electric Head is offline   Reply With Quote Quick reply to this message
Old 01-21-2009, 11:03 PM   #5 (permalink)
Daz
Daz's Avatar
thanks peacekeeper I will give them a call.
Route66 it is a final drive conversion I am after, thanks all the same
Old 01-22-2009, 08:25 AM   #6 (permalink)
gtnot wants to know Dino or Syn?
You can also check www.3Guyz.com for final drive chain conversion kits.
gtnot is offline   Reply With Quote Quick reply to this message
Old 01-22-2009, 08:27 AM   #7 (permalink)
ChopperDude wants to know Dino or Syn?
http://letmegooglethatforyou.com/?q=...onversion+kits
ChopperDude
ChopperDude is offline   Reply With Quote Quick reply to this message
Old 01-23-2009, 01:05 AM   #8 (permalink)
dickey's Avatar
dickey is reading this now saying WTF is this?
Why on earth would you want to switch your belt for a chain?
dickey is offline   Reply With Quote Quick reply to this message
Old 01-23-2009, 09:17 AM   #9 (permalink)
For one... lets you put on a wider rear tire.
ChopperDude
Old 01-23-2009, 01:35 PM   #10 (permalink)
AZFXSTB's Avatar
AZFXSTB wants to know Dino or Syn?
Currently there are VERY limited options for this convertion the only one that is "ready" is the 3guyz one BUT it is a 530 chain and has a width wider than the current belt running through the swing arm and tire/fender area. As a result you have to use a spacer to shift the 200 rear tire.
Now that I wrote all this a see you have a Dyna not a softail like mine just slap me silly and move on, the Dyna should be alot easyer to do.
07 Train with extra fun & CHAIN FINAL DRIVE MOFOS!!
AKA: azleatherneck
Come say Hi
AZFXSTB is offline   Reply With Quote Quick reply to this message
Old 01-23-2009, 06:46 PM   #11 (permalink)
Tx_Outlaw's Avatar
Tx_Outlaw wants to know Dino or Syn?
First - in his above post, he stated it is for an '07 Softy.
Second - 3Guys uses an o-ring style 530 chain. Correct, this chain is a tad wider than the narrow belt used on the 200mm tire'd bikes. A standard 530 chain is not wider tho......
Chuck
'o6 FXSTBI
Slightly Modified......
Tx_Outlaw is offline   Reply With Quote Quick reply to this message
Old 01-24-2009, 04:26 PM   #12 (permalink)
AZFXSTB's Avatar
That would get you by without useing the shim but $519 is CRAZY to charge for the setup 70-100 bucks for the front sprocket same for the rear and 100 bucks for the chain and thats being fluffy still. I asked why and was told it was because of the blanching setup for the new splins on the sprocket for the front...ill wait for that to come down to earth first.
Also is the offset for the front sprocket assuming you will be useing the spacer on the rear so you can use the 530 O-ring chain and if so that offset is wrong if you go with a standard 530 chain.
Personally I am pretty surprised this issue is such a speculative area. I would have thought there would be enough demand for this convertion to have all the bugs worked out by now 2+ years after the release of this setup.
AKA: azleatherneck
Come say Hi
Old 12-28-2010, 12:37 AM   #13 (permalink)
AZFXSTB's Avatar
Oh a blast from the past....almost 2 years later, 3 belts Broke and still no bolt on solution.....but STAND BY I feel a surprise brewing.
AKA: azleatherneck
Come say Hi
Old 03-05-2011, 07:51 PM   #14 (permalink)
AZFXSTB's Avatar
Don't want to steal any thunder but, I have just helped with the development of a bolt on belt to chain conversion with the 06+ 200mm rear softails...530 o-ring chain and it fits. ONLY mod is a little inner fender clearance you need to do with a dremel takes 5 min...true bolt on...details to follow...off to ride NO MORE BROKEN GD POS BELTS!!!!!!!!!!!!!!!!!!!!!
I will say their name has been spoken in this thread!
AKA: azleatherneck
Come say Hi
Old 03-29-2011, 12:15 PM   #15 (permalink)
sethlee11 wants to know Dino or Syn?
I've got an 08 train looking to put the chain on. My builder said we would be one of the first to make a chain drive for a newer softail. What sorts of offsets did you use?
sethlee11 is offline   Reply With Quote Quick reply to this message
